rubicon rear end leak - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > rubicon rear end leak
Poison Spyder DeFenders™ - "Tubeless" Jeep FendePoison Spyder Dana 44 Bombshells Are BACK!!Poison Spyder RockBrawler II Rear Bumper with Tire Carrier
Unread 07-25-2007, 08:45 AM   #1
rubi03
ok so i have a 03 jeep rubicon and i was looking at the back of the jeep today and noticed i have fluid that seems to be leaking out of my rear axle tube on to my tire on the passenger side. anyone got any ideas why this might be happening??
rubi03 is offline   Reply With Quote
Unread 07-25-2007, 09:09 AM   #2
fish4life
i see that same spot is a little greasy on my D35, but i have never seen it drip, and no significant fluid loss as of yet
curious what it is myself...
fish4life is offline   Reply With Quote
Unread 07-25-2007, 10:27 AM   #3
rubi03
update on the rear diff leak.. the whole inside of the rim is caked with what smells like gear oil. is there a seal that may have gone out?
Unread 07-25-2007, 10:30 AM   #4
jdarg
Yes, front and rear axle seal leaks are fairly common on earlier Rubicons. You might want to check out ******************.com for additional advice as a lot of people there have dealt with this.
-jd
'94 YJ - 34x10.5 Super Swaper LTB "pizza cutters", 2.5L/AX5/231, D30/8.8 4.88, 63mm throttle body and manifold, electric fan, Dynomax exhaust, SYE/CV, SOA on stock springs, MORE traction bar, Teraflex tummy tuck, Milemarker 9500 hydraulic winch, various skids
'06 LJ Rubicon - 31" Trxus, OME 2.5", belly up, various skids
'75 CJ5 basketcase
brewcitycrawlers.com
jdarg is offline   Reply With Quote
Unread 07-25-2007, 10:31 AM   #5
jdarg
-jd
Wow, this forum blocks out the names of other forums in posts?
'75 CJ5 basketcase
Unread 07-25-2007, 10:38 AM   #6
UTIJeeper
i have 03 rubi axles under my 97 tj and my driver side leaks very bad...especially for a few days after whellin...I just built these axles like 1 year ago and they have been leaking since 4 months after i built them...i don't know what the deal is...the tube seals look fine..i just bought some new ones...we shall see what happenes..any ideas why these axles leak like this??? or any fixes!!
Wheelin'
UTIJeeper is offline   Reply With Quote
Unread 07-25-2007, 08:49 PM   #7
JerryC
Your axle seal is bad. It needs to be replaced.
JerryC is offline   Reply With Quote
Unread 07-25-2007, 08:54 PM   #8
JerryC
If you are referring to the front axle, the tube seals at the u-joints are simply dust covers. The actual front seals at the inner ends of the axle tubes, and are accessibe only by removing the diff cover, axles, and differential.
