#1 | |
rubicon lockers in high range?
I would like to wire my factory rubicon lockers to work in high range also. Is it as simple as clipping single wire comming out of transfer case and adding a toggle in line to a ground?
#2 |
Yes it is, you can do it right behind the locker switch on the dash...very easy. http://www.rockcrawler.com/techreports/jeep_rubicon_locker_bypass/index.asp
#3 |
cool, thanks
#4 |
#5 |
I used the method to engage use in either range, but still had to be under 10mph to engage, so didn't see the need for an additional switch.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
