Rubicon Locker Bypass Switch - JeepForum.com
post #1 of 24 Old 02-14-2007, 09:40 PM Thread Starter
robert92679
I was looking at a write-up on how to bypass the Rubicon lockers safety so the lockers can be used in 4W-Hi. Here's a link:
http://www.rockcrawler.com/techrepor...pass/index.asp
I like the idea of a switch to enable the bypass. Other write-ups I've seen didn't include the switch and I was concerned that the lockers might be accidentally engaged at the wrong time.
The write-up suggests some aftermarket switch, but I'm looking at my panel and there are three open positions for additional factory switches that I don't have.
Does anyone know that part number of a generic on/off factory switch that I can install in one of those positions? My Jeep is a 2005.
Thank you!
2005 Unlimited Rubicon
robert92679 is offline
post #2 of 24 Old 02-15-2007, 10:04 AM
Xlr8n
1986 TJ Wrangler
There are three different ways you can jump the switch to bypass it. The number one and four pole jumper method will let you use the lockers in 2hi and 4hi, but will retain the factory setting of having it not engage at speeds above 10mph. This should eliminate them accidentally being engaged at speeds that would be dangerous. This is also the bypass I used and have had no issues with it.
Xlr8n is offline
post #3 of 24 Old 02-15-2007, 12:47 PM
jalbs
Do you have a link for the "number one and four pole jumper method"?
jalbs is offline
post #4 of 24 Old 02-15-2007, 01:27 PM
Xlr8n
1986 TJ Wrangler
It's in the o.p.'s link: http://www.rockcrawler.com/techrepor...hoto=chart.gif
Xlr8n is offline
post #5 of 24 Old 02-15-2007, 01:59 PM
whitham_wannabe
But then they disengage at 10mph .... I bypassed mine completely and instead rely on the big orange lights in the dashboard and common sense to know when I'm locked.
whitham_wannabe is offline
post #6 of 24 Old 02-15-2007, 02:10 PM
Xlr8n
1986 TJ Wrangler
Uhh, seems you may be confused on the operation of the diffs. They have a factory setting that keeps them from being activated above 10mph, but once activated they will stay activated, even at speeds faster than 10mph . You can disable the 10mph activation feature as you have done, but the benefit of the 10 mph activation limit is to keep curious passengers or the driver trying to find another switch from poking the button at higher speeds and sending the vehicle out of control or depositing parts of the TC and diffs onto the highway.
Xlr8n is offline
post #7 of 24 Old 02-15-2007, 02:51 PM
55willystruck
This is correct. From the factory, the lockers have safety's built in that prevent engagement above 10mph, and will dis-engage at above 45mph-supposedly. Jumping pins 1&4 retain factory safety parameters, so that in 4-low, you still need to be going under 10mph to engage, and they will still (supposedly) cut out at over 45mph. I installed a separate switch in my rig so that with my "safety" switch, lockers can only be engaged in low range, just like factory. However, once I turn "on" my safety switch, I can then engage the rear locker in 2wd, or front and rear both in 4 high. This is especially useful in snow-or at least, that's where I've used it most.
HOWEVER, the original poster is not asking how to do the mod, he's instead asking for generic replacement switches like the factory uses. So-have you checked your dealer? They are probably more expensive I would bet. I got a replacement factory locker switch from someplace called "Jeepsareus" or something similar I think??? I forget exactly what it's called. They had similar switches that looked basically like the factory switch, and fit the factory holes, but were "blank", or blacked out-as in no symbols on them. I'm sorry I forget the exact name of the place-perhaps somebody can make sense of who it is I'm referring too and be more useful than I.
Best of Luck,
Mike
55willystruck is offline
post #8 of 24 Old 02-15-2007, 02:54 PM
nicolas-eric
one other question:
can i modify the swithes somehow? a friend wants to use the front locker without the rear locker.
thanks.
4" OME & 1" Spacer & LT Shocks 2" BL 1" MML JKS Discos JKS Rear Links OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 ARB Airlockers ARB Diff Covers 4.56 Gears SS Brake Lines
Warn Skids Genright Rock Slider Smittybilt Rock Crawler Rear Bumper Safari Snorkel OBA
12.000 lbs Winch Synthetic Winch Line 4x 130W Hellas 4x 200W Hellas @ Lightbar E-Fan
nicolas-eric is offline
post #9 of 24 Old 02-15-2007, 03:32 PM
Xlr8n
1986 TJ Wrangler
Originally Posted by nicolas-eric
one other question:
thanks.
Yes, you can wire them independently with two switches. Here's a how-to (half way down the page): http://www.wanderingtrail.com/Rubi_2...ker_Defeat.htm
Xlr8n is offline
post #10 of 24 Old 02-15-2007, 03:40 PM
Xlr8n
1986 TJ Wrangler
The o.p. stated he wanted a switch because he was concerned that the lockers could be activated at the wrong time, and I was suggesting a method of bypassing the 4-lo only operation and still retaining the safety of not engaging above 10mph which would acheive his goal without using a switch. Hope this clarifies the intention of my post(s).
Xlr8n is offline
post #11 of 24 Old 02-16-2007, 09:48 AM Thread Starter
robert92679
Thank you, I appreciate the suggestions for Jeepareus and for the <10 mph by-pass.
I was actually considering wiring the switch to behave like stock in the off position, and activate the <10 mph in all ranges by-pass when on. That might be overkill, but I've already had more than one 'curious passenger' poke at the switch and say, "Axle Lock, what's this do?"
I haven't checked with the dealer, partly because they may not be too interested in helping me defeat their safety system, but also because my FSM says that the stock switches (rear defogger, washer, OD disable) are momentary switches that activate electronic relays in those systems. The by-pass switch is just SPST.
post #12 of 24 Old 02-16-2007, 10:09 AM
Xlr8n
1986 TJ Wrangler
I doubt you'd have any problems with accidental engagement doing the 1-4 jumper. If someone did accidentally poke it below 10mph, you'd feel it immediately and could switch it right back. Also, it's only the cost of a paperclip and five minutes of your time.
Xlr8n is offline
post #13 of 24 Old 09-25-2012, 10:47 AM
oracle_man
tried to do the mod this morning, but for some reason, center dash bazel will not pull out and up, as according to http://www.rockcrawler.com/techrepor...pass/index.asp
Am I doing something wrong? The bezel will pull out about an inch or so, it just won't pull of or out any further. I might add that my dash and stereo are 100% stock in my 04 rubicon
oracle_man is offline
post #14 of 24 Old 09-25-2012, 11:36 AM
oracle_man
nevermind. I got it. It was just a took quite a bit more force to get the lower part of the bezel to free up from the friction tabs.
post #15 of 24 Old 09-25-2012, 02:47 PM
oracle_man
Works like a charm.
Locker lights flash after switch bypass kuebelwagen TJ Wrangler Technical Forum 6 01-08-2010 08:27 PM
Rubicon bypass and 2 locker switch question Squint77 TJ Wrangler Technical Forum 14 01-19-2009 03:46 PM
New light switch?(Rubi locker Bypass) Deezul TJ Wrangler Technical Forum 2 06-04-2006 11:27 AM
locker bypass switch WarrenNJ TJ Wrangler Technical Forum 8 04-12-2006 07:29 PM
Rubi locker switch bypass? cisco04 TJ Wrangler Technical Forum 7 01-06-2004 10:46 AM
