Rubicon Locker Bypass - JeepForum.com
post #1 of 16 Old 01-11-2005, 08:14 PM Thread Starter
wherndon
What the hell?
wherndon's Avatar
I was just wondering how many Rubi owners has done this bypass?
edit: almost forgot the link http://www.rockcrawler.com/techrepor...pass/index.asp
Since I drive in an area where there is lots of mud and water, I can definately see the advantage of having the lockers in 4WH.
Whattaya think?
________________________________
'05 Rubi, Patriot Blue, RE SF, Antirock, Warn, Fabtech, Tomken
_________________________________
2000 Grand Cherokee Laredo V8, Patriot Blue
Stock
'93 YJ Sport, Canyon Blue
4.0, auto, air, limited slip, HT.
2.5" Rancho suspension, Ramsey 8000
Previous Jeeps...
'91 XJ Laredo, white
'87 YJ Sport, white
wherndon is offline
post #2 of 16 Old 01-11-2005, 08:17 PM
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
2009 JK Wrangler
I did for a little while, but ended up shorting out my switch. I never bothered to redo it since I didn't actually use it that much. I try to stay out of the mud because I don't like cleaning much.
SlinkyTJ is offline
post #3 of 16 Old 01-11-2005, 08:54 PM
igofshn
Locked @ both ends
igofshn's Avatar
Added to the FAQ.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 16 Old 01-11-2005, 09:02 PM
rubi-soho
rubi-soho's Avatar
My .02, your just asking for trouble. I have a Rubicon 5 speed and have had to go through some mud-lakes while in TX and I just used 4th and 5th 4LO, the lockers work up to 45 mph then disengage. I think it would be unsafe to lock-up and go any faster than 45, while spinnin' wheels and Evil-Kniveling my way across a mud pit.. I'd rather just muscle my way through, avoid mud all together, or just see how it goes and winch out if needed. But I dont like mud anyway, I'll stick with rocks...they are a lot easier to clean off anyhow
rubi-soho is offline
post #5 of 16 Old 01-11-2005, 09:05 PM
got4-Lo
sondslike if u mess up ur screwed
stretched *** tj
got4-Lo is offline
post #6 of 16 Old 01-11-2005, 09:11 PM
87warrior
87warrior's Avatar
I have not and do not plan to do this. Why? It is just not practical for me Right now my Rubicon is the best and never gets stuck... NOT. I just avoid the mud, and it would be useless on the rocks
If I lived in an area where there is a lot of mud and what not I would do it. Now say I am going to do the bypass. I would wire it so the lockers will only engauge under 10mph in either mode of 4wd. You DO NOT want to engauge any sort of locker going to fast. You are just asking for an axle to explode.
03
(Rubicon build)
92
(92/99 Comanche Project)
86
(Heavy Four)
87warrior is offline
post #7 of 16 Old 01-11-2005, 09:19 PM
rubi-soho
rubi-soho's Avatar
I agree with 87warrior, I'll never do this mod. and I have only had to use them a few times ( and probally didn't really need to ) but I have really needed them two times....to pull full-size chevys (IFS) out i wish I had pics...they were both stuck at the same spot and lucky for them I came around the corner and saw the poor chevy guys jacking and moving rocks.... they thanked me and turned around and went home.....haven't pulled a hummer yet....but hope i will soon....
post #8 of 16 Old 01-12-2005, 01:08 AM
Rubicon it
I've done it and used it. But I only use it when I need to. No problems whatsoever. Been happy with it and it's just another mod that doesn't cost over 500 bucks.
Rubicon it is offline
post #9 of 16 Old 01-12-2005, 02:03 AM
TJRubicon
TJRubicon's Avatar
I have also thought about doing something like this, but I had being able to select which locker was on or off in mind. I'd rather be able to just turn on the front locker in most situations I've been in that required them at all instead of both.
Are there any write ups on doing this?
04 Rubicon, RE SF 4.5, 1"BL 1"MML, ProComp SS brake lines, ProComp Shocks, Currie Anti-Rock, 35" M/Ts, AR767 15x8 black steelies,
front bumper & rockers
BLUE JEEP CLUB MEMBER #128
TJRubicon is offline
post #10 of 16 Old 01-12-2005, 08:02 AM
PdXmAc
PdXmAc's Avatar
I've done this mod, and I have used it several times. Where you will find a great benefit is in deep snow. I was out snowmojeeping this past weekend, and got stuck 4 low was too low, couldnt get any momentum. And 4 high wasnt getting me there, but when I locked it up in 4 hi..I drove out of there like greased lightning! My buddys were amazed. You do have to be careful, and not abuse your new privledge, but it is definately a useful mod. All things in moderation boys....
"I feel alot more like I do now than I did before"
2005 SWB Rubicon
6-speed
PdXmAc is offline
post #11 of 16 Old 01-12-2005, 10:05 AM
Rubicon it
Must of been up at TSF?
post #12 of 16 Old 01-12-2005, 11:08 AM
KD5LEF
KD5LEF's Avatar
I have thought about doing it . But I want to know if I do it, will it void any warranty. More to the point - my electrical warranty. If so, I will wait.
1 Divorce.....countless $$. 2004 Jeep Rubicon - Armored, lifted, new tires, wheels, tire carrier. Winch to come - PRICELESS!!
3inch OME, JKS goodies, 1.25BL. 33x12.5 BFG KM2's
KD5LEF is offline
post #13 of 16 Old 01-12-2005, 12:12 PM
PdXmAc
PdXmAc's Avatar
Nope, up above Carson, WA, near Mt. St. Helens. lots of FUN!
2005 SWB Rubicon
6-speed
PdXmAc is offline
post #14 of 16 Old 01-12-2005, 12:16 PM
PdXmAc
PdXmAc's Avatar
You dont modify the wiring harness at all, and can be reversed without detection in 5 minutes. All you are doing is sliding wires into the back of the plug behind the lockerswitch. Just make a three-wire jumper out of 16ga wire and slide the wires in next to the appropriate wires in the pigtail. Worst case, if you are paranoid, take the 5 minutes and pull the pigtail out before you go to the dealer if you shoudl have warranty problems.
2005 SWB Rubicon
6-speed
PdXmAc is offline
post #15 of 16 Old 01-12-2005, 06:28 PM Thread Starter
wherndon
What the hell?
wherndon's Avatar
Actually I wouldn't be interested in going fast. 45mph is too much for trail riding imho.
The kind of trail riding I usually do doesn't require 4wl too much, only a constant speed.
Stock
Previous Jeeps...
'87 YJ Sport, white
wherndon is offline
Rubicon locker bypass ? steveazoni TJ Wrangler Technical Forum 4 02-09-2009 12:09 PM
Rubicon locker bypass question melius Wrangler General Discussion 0 09-07-2008 09:10 AM
Rubicon Locker bypass - has anybody done this mod? vetdezracer TJ Wrangler Technical Forum 8 02-29-2008 03:25 PM
Rubicon locker bypass problem spyder6 TJ Wrangler Technical Forum 6 03-22-2007 12:52 PM
