Rubicon Locker Air Pump question (how to wire your Rubicon air pump)
#46 | ||
red (power)/black = click pink( Power)/black = Runs very slow and will not shut off ( actually it's sucking air on bottom outlet) pink (power)/ Red = runs very fast...but it's still sucking air maybe one of the spliced wires that are being hooked up needs to be separated. Who knows
#47 |
Just an update, I ordered a new set of pumps from jeepsareus. They arrived today so I hooked them up and as it turns out they operate the same way as paultyler's: red is power, black is ground, and the pink is not needed.
Gave the jeep a little test drive on a dirt road by my house and they work like a charm. |
#48 |
Just as an FYI. I tested a set of these pumps to see what the PINK wire was all about. I used Black as ground, Red as power, and connected the PINK to the voltmeter. While the pump was off or on but below pressure, the Pink had 0 VDC. When the pump reached pressure and stopped, the PINK wire had 12 VDC. My pump came from an '05 but I don't have a wiring diagram for that year. I am assuming that this PINK wire is a switch to pass information somewhere else. Any more insight is appreciated.
#49 | |
Yep this is exactly the way to do it. Apparently when i was trying to figure this out before searching i hooked up the pink wire and it ruined the pump (makes a single click when hooked up red to power and black to ground). So when i ordered a new one i immediately taped up the pink and hooked up the red and black only. Works perfect. |
#50 | |
Doug www.4x4LED.com - LED lights for Jeeps, cars, trucks, trailers, etc.!! Tiedowns for your Jeep trailering needs! Envy4x4.com Suspension parts/kits, CBs and accessories and other Jeep doo-dads, MOLLE bags and packs too! |
#51 | |
Uncle Paul has spoken...
My Jeep - Video My Jeep in the Snow 92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com) |
#52 | |
At first with all this different pink and red wire stuff I was wondering if the 03 rubicon pumps were different from the 04-06. However looking at the dealer they said its the same p/n for 03-06.
[b]03 Rubicon 5SPD, 2.5 RC Lift, Skid Row EngineTrans Skid, MG LCA Skids, Rancho Xtreme LCAs, & JKS Discos. ---->[url=http://www.jeepforum.com/forum/showthread.php?p=6641775#post6641775]SOLD 03-06 Skid RowEngine/Trans Skids SOLD!!![/url] <----[/b] |
#53 |
seriously guys, the click that you guys are hearing is the solenoid closing to hold the pressure and shutting off the pump.
The way you guys have it wired up will work just fine. The pump just pumps until it peters out. Think about this though, if you hold an electric fan still and turn it on, how long do you think the motor will last? It's made to turn when turned on. When not in use the power is shut off. The pink wire shuts off the pump AND closes the solenoid to hold pressure. It is wired thru the locker itself so that when it gets a signal (connection between the two sides of the locking mechanism) it closes the solenoid and cuts power to the pump until the signal is lost (due to pressure bleeding down) or the switch is turned off. And yes, it does also power the light in the dash (if you so choose to install one). Like I said before, it will work fine the way you guys have it wired. Just trying to let you guys KNOW FOR FACT the intended purpose of the pink wire. I'm the only person here that has given a tested and proven use for the pink wire. All the rest have been "well it's probably just to..." Guys, I'm not trying to be a horses butt about this, just trying to help you guys understand the purpose and use of the wires. Don't take this post the wrong way, please. For informational purposes only!
Eric Baker 97 TJ 6" lift, 35 x 1250 MTR's Rubicon 44 front w/factory air locker 8.8 rear w/full Detroit 5.13 gears, SYE, etc, etc, etc.......... |
#54 |
tjrunner, if what you are saying is true, then wiring up the pumps the way we have them wired (red-power, black-ground) should just cause that single click of the solenoid to shut off the pump. That is not the case however, the pump runs full blast when wired this way.
Also, how do you explain the pink wire getting power once the proper line pressure has been reached? There must be some internal sensor that powers that wire once the proper pressure is reached and the pump shuts off. I'm not trying to be a ****, but your pump behaves differently than the one that I have. |
#55 | |
From memory I know for a fact there are only two wires per pump in the vehicle harness (power and ground, no signal from the diff switch) that runs under the tub to the lockers. One of those wires is connected to one wire on the pump and the other wire connects to *two* wires on the pump. So *three* pump wires are used but only two are in the harness. I can't remember the colors off the top of my head, though I think red+pink are the parallellel wires on the pump, connected together to one of the harness wires. I will look when I get home - rode the bike to work today.
'94 YJ - 34x10.5 Super Swaper LTB "pizza cutters", 2.5L/AX5/231, D30/8.8 4.88, 63mm throttle body and manifold, electric fan, Dynomax exhaust, SYE/CV, SOA on stock springs, MORE traction bar, Teraflex tummy tuck, Milemarker 9500 hydraulic winch, various skids '06 LJ Rubicon - 31" Trxus, OME 2.5", belly up, various skids '75 CJ5 basketcase brewcitycrawlers.com Last edited by jdarg; 07-03-2008 at 11:10 AM.. |
#56 |
wow... i'm bringing this one back from the dead ..... Here's what worked for me (after blowing one pump, if anyone has an extra pump please let me know) RED power black ground and the pump turns it self off ... DO NOT CONNECT PINK TO POWER AND BLACK TO GROUND because then the thingy inside will not work anymore and it will just click ... trust me i know... cause now i have a dead pump :'(
hope this helps -jason jay4554@aol.com
94 ZJ 31"MT/R 7" long arm KOR, NP231HD, K&N intake kit,MSD 6A box, ARB bull bar, M8000 warn, Zacatal roof rack, home built sliders, JCR OTK steering (PIA to install), high out put alt., bored TB, 3" exhaust... more soon to come |
#57 | |
Thanks
#58 | |
wait a sec.. do you know something i don't know.... the little guy still pumps but now when i connect it (red power black gound) it just clicks but if i go pink power and black ground .. the little thing pumps ... if i go red power pink ground .. the little thing goes crazy pumping ![]()
#59 |
Ummm..........no!........ummmm.........yeah it's toast! Ship it ups red today please!!! lol
But seriously, your pump is fine. Just run it like these guys are saying to. It will work fine. I have mine hooked up correctly and even put a dash light indicator on it last week. It works fine ALSO. I did find out for how the rubicon stuff works though(only able to turn on the lockers in 4wd, the dash light, cant turn on the front locker until the rear locker is on, etc...). It DOES NOT run through the ECM. Glad you guys got you pumps to work. Anyone else who wants to know the exact workings of it all can email me. Going to bow off this thread. I seem to be confusing more people than I'm helping. Sorry
#60 |
PM'd and emaild u TJ
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
