Rubicon Locker in an 03-06 LJ d44 - JeepForum.com
post #1 of 9 Old 07-25-2010, 05:27 PM Thread Starter
iowaneedshills
I just came across a rear dana 44 locker from a rubicon.
I found a few posts on here that said 2003-2006 TJ sport and LJ Unlimited jeeps had a slightly larger d44 housing that would accommodate the locker. Can anyone verify this?
I'm planning to use this as part of my upgrade to 4.88 gears. I'm assuming I'll have to buy thick-cut rubicon gears, right?
I figure I'll need a switch, electrical wire, a rubi air pump, and air line. Am I missing anything?
iowaneedshills is offline
post #2 of 9 Old 07-26-2010, 09:19 AM Thread Starter
iowaneedshills
anyone?
post #3 of 9 Old 07-26-2010, 09:55 AM
gribbles
youre right on the housings being different - I'm running a front rubi locker in my TJ d44 housing (sourced from a 98) and when I was doing the research I came across this same info.
Yes, you will need thick cut gears and you'll also need to tap the 44 for the air line - I used an arb fitting and airline but the stock rubi pump
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #4 of 9 Old 11-30-2011, 05:39 PM
flip2spin
Any more information on this ?
flip2spin is offline
post #5 of 9 Old 12-01-2011, 09:47 AM
gribbles
what else do you need - my original post a year and half ago answered it
2007 WK CRD
gribbles is offline
post #6 of 9 Old 12-01-2011, 09:52 AM
JeepManager
So we should assume you're thinking of putting it in a D30 then?
JeepManager is offline
post #7 of 9 Old 12-01-2011, 10:15 AM
chevy2169
LOL! BOOM goes the front axle!
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dip****s.
chevy2169 is offline
post #8 of 9 Old 12-01-2011, 10:35 AM
flip2spin
got a link to it ?
post #9 of 9 Old 12-01-2011, 10:42 AM
gribbles
see post #3
http://www.jeepforum.com/forum/f9/ru.../#post12598041
2007 WK CRD
gribbles is offline
locker , rubicon , lj , tj , wrangler , compatible , differences , axle , d44 , dana 44
Rubicon Locker Air Pump question (how to wire your Rubicon air pump) paultyler TJ Wrangler Technical Forum 167 03-26-2015 06:49 PM
Rubicon locker. 00jeepred TJ Wrangler Technical Forum 0 01-25-2010 08:50 AM
Need some help with my Rubicon Locker` rubbertoe TJ Wrangler Technical Forum 5 09-23-2009 01:31 PM
rubicon air locker? PatrickMintun YJ Wrangler Technical Forum 10 06-20-2009 07:24 PM
ARB air locker vs. Rubicon locker in my TJ Glass TJ Wrangler Technical Forum 27 08-09-2005 06:23 PM
