Rubicon front axle on a x model. What do I need?
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
I am helping my dad put a rubicon front axle on his jeep, he wants to make the stock locker work. He purhcased a new ring & pinion(4.88) for it, and all he needs is the stuff to make the locker engage. Is there an after market kit to make it work? He thought about sticking an after market locker in, but he likes the functionality of the selectable lockers.
www.riversedge4x4.com '78 CJ- 5 (O'l Green), '99 TJ on rocks (li'l man), '07 JK (rattle can) |
#2 |
Is it a TJ or the JK listed in your signature, if it is the JK, post in JK forum, give specs on the jeep
2006 Wrangler X, 6 speed manual 4.0 I6, BFG T/A's 31x10.50x15 on Promcomp )97 Soft 8 Steelies, stock sunrider soft top, KC Replacement fogs, westin step bars (yeah I know). RED JEEP CLUB MEMBER #442 |
#3 |
If it is a TJ, see if you can source a stock Rubi locker pump, otherwise you'll need a compressor and a regulator to match the approx. 5psi that the lockers require.
Additional stuff: - shortened front driveshaft (Rubi D44 pinion is about 2" longer than the D30) - new pinion yoke to accept the 1310 U-joint on your stock driveshaft OR a new driveshaft yoke to accept the 1330 U-joint for the Rubi pinion, either will work, but the 1330 is a little stronger. Other than that it's a straight bolt in. |
#4 |
You can also use a combination 1310/1330 ujoint.
#5 | |
#6 |
ebay for a rubi locker pump. if not put some on board air in and route a line to the front diff with a regualtor.
#7 | ||
'02 TJ, 3.5" RE lift, super 35 kit, detroit locker rear, 4:88 gears, about to install a rubicon t-case, and a rubicon front axle. ![]() Quote:
#8 |
Not to Flame you or your pops, but I wouldn't go through the hassle of installing a rubi front axle into my tj. A lot of the parts on the axle are the same as the D30 and not much stronger. I have been advised against this before, twice. Just my two cents
#9 | |
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
#10 |
Jeepaholic
Not to mention a stronger ujoint in the drive shaft and a locker as well.
#11 | |
Do it right or not at all
![]() Join Date: Jan 2003
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#12 |
i think i'd rather upgrade to a rubi rear instead of a rubi front
2002 tj sahara 3" lift 35" km2, AtoZ rockers 10k lb winch, 4.56 gears, lock-rites front and rear My jeeps Carolina Offroad Forum Coastal Carolina Offroad East Coast Trail Raiders |
#13 | |
#14 |
I think he has a Super 35 Kit in the rear. A 44 would only really strengthen his tubes right?
#15 |
JEEP FREAK
D44s have the same axle tubes. The housing is still slightly stronger though because of the larger center section.
The D44 ring gear (8.5") is also stronger than the D35 ring gear (7.6"). The D44 pinion gear is comparable in strength to a D35 pinion gear. Super 35 axle shafts are stronger than stock D44 axle shafts.
98 TJ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
