Rubicon front axle hub conversion - JeepForum.com
post #1 of 25 Old 09-28-2007, 07:46 PM Thread Starter
plowe
I'm trying to find manual locking hubs for my 04 Rubicon, and have had no luck. Is it because of the locker? What gives? Anybody got any suggestions or ideas?
plowe is offline
post #2 of 25 Old 09-28-2007, 08:00 PM
ej's tj
ej's tj's Avatar
What hubs?
TJ's do not have any type of disconnect between the axle and the wheel. When you are in 2wd the front drive shaft is diconnected from engine power at the t-case but it is still spinning when you drive because the axles are connected to the wheel/hub. To my knowledge there is not a hub conversion of any kind for a TJ with out changing a good deal of other things. I believe there may be something from Warn but usually the only mod to the front axle in this respect is heavier duty axle shafts.....hope this helps
2005 Unlimited Rubicon bright red, wet okole, 2 1/2" (more like 3"+) HD OME 1 1/4" JKS BL, JKS Discos, 1" JKS MML,28575R16 BFG MTs, Custom HD rear bumper, 2 year old Akita,
9500 lb. milemarker winch, kilby gas tank skid, home made rear bumper and tire carrier, lite dot taillights, more to come!!!!!!
Integrity is a rare find!
ej's tj is offline
post #3 of 25 Old 09-28-2007, 08:07 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Why do you want a hub conversion?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #4 of 25 Old 09-28-2007, 11:05 PM
cjheap
better fuel mileage
servicable bearings
D44 outer shafts
less wear on front axle parts
the Warn kit runs $1100 but if you need to replace your unit bearings anyway, go for it.
cjheap is offline
post #5 of 25 Old 09-29-2007, 07:41 AM Thread Starter
plowe
I realize they don't, and I know how everything works They make a kit, but it says not for Rubicon and I was wondering why. I tried calling the manuf. but could not get any info as to why, other than D44 axle and wanted to change them out for the less wear, better mileage attributes
plowe is offline
post #6 of 25 Old 09-29-2007, 07:49 AM
The Mean Fish
The Mean Fish's Avatar
Originally Posted by cjheap
better fuel mileage
servicable bearings
D44 outer shafts
You won't get better fuel mileage with a front hub conversion kit.
Originally Posted by 84 CJ7 View Post
The Mean Fish you seem to hate big business and love big government. My guess is you are drinking the coolaid that Pelosie, Reid, Barny Frank, Biden, and Obama are serving.
The Mean Fish is offline
post #7 of 25 Old 09-29-2007, 08:28 AM
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
X2 you wont get any better mileage with a hub. That's just a jeeper legend .
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline
post #8 of 25 Old 09-29-2007, 08:42 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
better fuel mileage
You may get better mileage, but the increase is so small that a run down the freeway at 65 will do better due to the massive frontal area and poor aerodynamics of the Jeep.
servicable bearings
Your bearings are serviceable now. Remove the stub shaft nut and the 3 knuckle side bolts and pop in a new one.
D44 outer shafts
Unless you get the 5.5 hub kit, you aren't getting a 44 outer and if you do, then you have to change rims.
Argueably that might be true, but there are thousands who run without the kit and suffer no ill effects.
How does 200 dollars worth of unitbearings play into this?
Don't get me wrong, I'm a huge fan of hub kits and have and have had many of of Warn's very fine products, but you need to get one for the right reasons. That would be the ability to unlock the hubs to get home if you take out a driveshaft and stronger much higher quality axle shafts.
I am Savvy
mrblaine is offline
post #9 of 25 Old 09-29-2007, 09:50 PM
cjheap
Funny how a bunch of people who have no experience with the conversion are EXPERTS
1st, unlocking the hubs so that you are not turning the axle shafts, diff and front drive shaft reduces friction enough to gain 1-2 MPG, that is my experience. BTW, when the vacume hubs on my superduty failed and would not unlock, the inverse happened and the mileage dropped. Installed warn hubs and mileage went back up.
The bearings are larger and stronger than the POS unit bearings
The outers are the same size and strength as D44 alloy outers
And I am working on a junkyard conversion now that will be more reasonable and will be 5 x5.5 since my alloy rear axles are dual pattern. That will be much more convienent for me since I have multiple sets of beadlocks and tires for my CJ.
And for fitting the Rubi, it should since a Rubi 44 used D30 outer assemblies
cjheap is offline
post #10 of 25 Old 09-29-2007, 10:18 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
who are you responding to?
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #11 of 25 Old 09-29-2007, 11:45 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You would be the rare exception in a TJ to get 2 miles more per gallon.
Bearing assemblies that typically go 100,000 miles as the norm, and have never broken yet that I've ever seen anyone post are Piles of Poo? Try again.
Can you be more specific? Which outers are the same size and strength as which Dana 44 alloy outers?
Junkyarded 5.5 stuff isn't hard. It's the 4.5 stuff that gets harder to do out of the JY.
I am Savvy
mrblaine is offline
post #12 of 25 Old 09-30-2007, 12:49 PM
ej's tj
ej's tj's Avatar
Oh, sorry, I did not realize your level of knowledge.....just trying to help out....have a nice day......
ej's tj is offline
post #13 of 25 Old 06-26-2015, 11:13 AM
unlimitedTJrubi
I have a 2006 TJ Rubicon LJ edition that I am looking to do locking hubs on, or a 2 low kit for a couple of reasons... and locking hubs makes better sense than the 2 low kit because it accomplishes it all.
1) When backing a trailer having the ability of low range without the front binding immensely helps. A 2 low kt would work for this.
2) when I go wheeling during the summer time, the ground is so hard that in most cases 4 wheel drive binds the front end, having the ability to use low range without the front binding would be a great advantage. In this case a 2 low kit would work and give the ability to switch to 4 wheel without getting out to lock the hubs.
3)If I were to break an axle on the trail I could unlock the front and drive home hopefully without adding to said damage. A 2 low kit would not help here.
The downfall is that I would no longer have sealed bearings and would have to disassemble and repack bearings very year or so, not a huge deal, I've done it before.
I have an old waggy Dana 30 with locking hubs but drum brakes, and I have a Dana 44 locking hub 8 lug axle that is busted but still very much complete from hub to hub. Neither of these is ideal for doing the swap I want to do. Ideally I would be looking for Disk brake Waggy or Scout outer knuckles with disk brakes but they're getting scarce. I have read a forum where a guy said that he used sidekick components and liked it but no technical writeup about that. I am not going to buy an $1100 kit that every time I need to change my rotors I need to take them to a machine shop and have them modified to fit my rig, that just seems insane to me.
I am not looking for flamers, I already have done the research, I know that going to manual hubs won't change my mileage, I know that I am going to have to change my front wheels at the very minimum, or put on offset spacers and go to 5 on 5.5 wheels all the way around, and I know that I won't be getting this done for cheap no matter which way I go.
What I want to know, is what has worked for others, besides the chevy 6 lug system, has anyone done the Suzuki swap? and If I do this swap, what more do I need to look into, steering components? brake lines? Offset U joint part #'s for the stub to the inner axle.
Before I commit to doing all of this I want my ducks in a row and I want to be able to have all parts collected and laid out correctly before I begin taking it apart and find out that I have missed something very important.
Thank you all in advance.
Dan
unlimitedTJrubi is offline
post #14 of 25 Old 06-26-2015, 11:24 AM
RenoF250
Is the a write up on how to do 5.5"? If I had a 5.5" 30 from aCJ would I have everything I need? I would like to put disconnects on the wife's TJ and 5.5" would be a benefit for me since I have a CJ so we would both have the same wheels, front bearings etc. Seems like only added cost would be new wheels and rear axles. Since the wheels were free and the axles are stock I am okay with that.
1985 CJ7 with 1994 4.6, Dana 44 4.10 TrueTracs
2001 TJ 4.0 Dana 44 4.10 TrueTracs
RenoF250 is offline
post #15 of 25 Old 06-26-2015, 11:30 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That's a good conversion, I did that to my previous TJ and have it on my current TJ as well. I don't believe Warn sells the conversion kits any more, only replacement parts so you're probably limited to a company like Yukon, maybe Milemarker still makes them too. Yukon's kit is at http://www.yukongear.com/ProductDeta...px?ProdID=9897. Otherwise you'd have to piece it together.
Jerry Bransford is online now
Rubicon front axle 00jeepred TJ Wrangler Technical Forum 16 01-21-2010 10:02 PM
Cheap hub conversion for front axle 472cid TJ Wrangler Technical Forum 0 02-03-2009 11:50 PM
TJ Rubicon front axle jappe TJ Wrangler Technical Forum 19 01-31-2009 03:41 AM
Rubicon front axle 4.10 -> 4.88 jappe JK Wrangler Technical Forum 2 04-02-2008 03:15 PM
D44 Rubicon front axle? Flash2004 TJ Wrangler Technical Forum 23 03-01-2008 07:28 AM
