Rubicon Express Lift Kit Dilema - JeepForum.com
post #1 of 34 Old 12-27-2005, 03:39 PM Thread Starter
method84
method84's Avatar
I've been doing so much thinking my head hurts. I still really don't know what I want for a lift. I know its going to be a rubicon express and I know its going to be either a 3.5" or a 4.5".
  • If I go with the 4.5" and then go with 35's can my front Dana 30 (stock handle) it...
  • I'm deffinetly going to go with a super35 kit for my Dana 35 but will it be able to handle 35's?
basically, If my rear and front axles cant handle 35's then Ill go with the 3.5" and 33's but I think I would be happier with the 4.5".....what do you guys think?
method84 is offline
post #2 of 34 Old 12-27-2005, 03:43 PM
goosevodka
I just put the 3.5" superflex on this weekend and man it is high, i think it is more than 3.5". I have 305/70's (33x12.50).
http://www.esentia.com
goosevodka is offline
post #3 of 34 Old 12-27-2005, 07:05 PM
sduncan
sduncan's Avatar
See my sig. 4.5 LA w/33s.
http://i15.photobucket.com/albums/a3...verLake004.jpg
http://i15.photobucket.com/albums/a3...verLake003.jpg
http://i15.photobucket.com/albums/a3...verLake027.jpg
'98 TJ, 5.7 HEMI,
sduncan is offline
post #4 of 34 Old 12-27-2005, 07:18 PM
Nickb1907
Nickb1907's Avatar
I have the 4.5" lift with 5.5" coils w/ 35s and stock dana 30 and dana 35
dont do any hardcore rock crawling just occasional trail riding, since this is me DD.
these are the lift with 32s, havent got any pics with the 35s yet.
Nickb1907 is offline
post #5 of 34 Old 12-27-2005, 07:36 PM
mtngoht
4.5 here.....
Definetly go with 4.5 if you plan on running 35's
Black Jeep Society
mtngoht is offline
post #6 of 34 Old 12-27-2005, 07:46 PM
yellj
If you go with the 3.5 which will get you around 4.24-4.5" of lift you can always add a 1" body lift and clear 35s. The advantage is a lower center of gravity, I plan on going to 35s this spring, just need adjust the bumpstops, that gives you an incredible amount of articulation. Not sure how to post pictures on this board, scroll down a little.
http://65.42.106.152/forums/showthre...ighlight=yellj
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
yellj is offline
post #7 of 34 Old 12-27-2005, 07:48 PM
beachtaco
beachtaco's Avatar
here is mine... RE 4.5" f coils/ RE 3.5" r coils/1" BL/dana 30/super 35 on 35" Truxus.
beachtaco is offline
post #8 of 34 Old 12-27-2005, 07:50 PM
Dirty Backroads
Dirty Backroads's Avatar
Here I was thinking "Those are some itty bitty 35s!"
2005 Solar Yellow TJ Sport
Yellow Jeep Club Member #123
Originally Posted by Sniper111
Nothing like going topless with some Kid Rock blasting looking down on the rice boys with their dropped Civics wondering what Japanese steel would look like under the Mickey Thompsons.
Dirty Backroads is offline
post #9 of 34 Old 12-27-2005, 07:59 PM Thread Starter
method84
method84's Avatar
That is such a sweet jeep ...Do you run hardcore trails? Have you broken a shaft yet?
method84 is offline
post #10 of 34 Old 12-27-2005, 08:02 PM
Scott_98TJ
I've run both, and would not go higher than the 4.5 coils with the short arms. I ran 3.5 coils and a 1"bl for a summer with 35"s. Just make sure your bumpstops are set, and frankly it's a good setup. Add a bellyup and all the trimmings to that and your really sitting very nicely for some good crawling. The 4.5 springs are good, and I run them because I wanted a bit more clearance and ability to carry the load... My TJ needs to go on a diet.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer
Scott_98TJ is offline
post #11 of 34 Old 12-27-2005, 08:15 PM Thread Starter
method84
method84's Avatar
If I go with the 4.5 do I need a 1" BL to clear 35's?
thanks
method84 is offline
post #12 of 34 Old 12-27-2005, 08:21 PM
dirtgrip
dirtgrip's Avatar
Shouldn,t with an RE 4.5in lift.It,s closer to 5.5in of lift.BL will be usefull for bellyup skids though.
Large vacuum leak sucking all the dead presidents out of my wallet.
dirtgrip is offline
post #13 of 34 Old 12-27-2005, 08:23 PM
AirborneSilva
AirborneSilva's Avatar
thanks
You may need to get longer bump stops. I had RE 3.5 springs on with a 1" BL and rubbed a little, after putting on 1" longer bump stops I had no problems. But now that I have the RE 4.5 springs along with the 1" BL I clear nicely Oh, I might add that it all depends on your tires too, some 35's run larger then others too....
04 Rubicon, Stone White w/all options, RE 4.5" superflex, 1" BL & 1" MML, Custom Front Bumper, Custom Rear Bumper w/swing out tire carrier, Custom Rock Rails w/steps, Mile Marker 12K winch/w Amsteel Blue synthetic line, 15X8 Black Rock crawler wheels w/35X12.5 Pro Comp Mudders, 800 watt power inverter. York OBA.
AirborneSilva is offline
post #14 of 34 Old 12-28-2005, 12:07 AM
Jr KLR
I'm not sure how serious of trails you are planning to do, but it seems like people who get 35's get them for hard core off-road use. With 35's you need to upgrade brakes and steering on top of the axles and gears. A properly set-up rig running 35's also has front and rear lockers. 33's will get you most places you want to go, and they look great if that's a factor.
As far as the lift, I think 4.5" is too much for a short-arm kit. The on-road ride will be worse than the 3.5". 3.5" should be the largest spring you put on a short arm kit, although many run the 4.5" and like it.
I think the biggest question you need to ask yourself is how serious of off-roading you do and how often you drive on the road.
2005 Silver TJ
Old Man Emu 2.5" HD kit on 32" BFG A/T
JB Super Shorty w/Tom Woods driveshaft, D30/D35 regeared to 4.10, MORE rear bumper, Skid Row Engine Skid and Gas tank Skid, Jeeperman Sliders, Warn steering skid, JKS Discos, Nth degree rear uppers, RE front track bar, RE adjustable superflex lower control arms, RE hand throttle, Tuffy center console, Magellean GPS w/mount, Hi-lift, Magnaflow muffler, dual tops.
Jr KLR is offline
post #15 of 34 Old 12-28-2005, 04:07 AM Thread Starter
method84
method84's Avatar
I do moderate to difficult trails depending on where I am for the day but nothing insane after all it is my daily driver. I think it might be in my best interest to go with the 4.5" kit with 3.5" springs this way down the road if I ever feel the need to go bigger or I want to upgrade then I already have a good foundation laid down. Thanks for all your help guys.
method84 is offline
Rubicon Express 3.5 lift? jerzyjeep09 JK Wrangler Technical Forum 13 08-26-2009 06:43 AM
BDS vs Rubicon Express (( Lift Kit )) gamer0 YJ Wrangler Technical Forum 17 04-21-2009 01:52 PM
Rubicon Express lift kit????? knotreeltight YJ Wrangler Technical Forum 12 12-09-2008 06:48 PM
Rubicon Express lift nickeagle TJ Wrangler Technical Forum 3 03-06-2008 09:01 PM
Rubicon Express lift rockrawling43 TJ Wrangler Technical Forum 18 04-13-2005 02:38 PM
