Rubicon Express bushings - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rubicon Express bushings
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!
Unread 07-20-2009, 10:41 PM   #61
glockster
glockster's Avatar
Well....I think our definitions of a stiff ride differ slightly. I didn't say worse, let me just clear that up.
I'm 48 with a surgically repaired back. The angles of the short arms in combination with the JJ's flat out hurt me sometimes.
For the record I had them installed at a very reputable shop, then sold the jeep within 10 months for other reasons. Mainly because I wanted the added wheelbase of the LJ. So far, the RE was the correct choice for me. If the bushings cause problems down the road I will replace them with the RE flex joints which are a 5 minute deal on the adjustable lowers I have.
Marco
Glockster's Rubihara Build
glockster is offline   Reply With Quote
Unread 07-21-2009, 04:25 AM   #62
Pillswoj
Originally Posted by imped4now View Post
Bushings suck on control arms, period. RE's bushings just happen to suck more than others. I'm surprised many of you are so surprised. It's not difficult to flex an arm outside of the small parameters of a rubber bushing. Do that a couple times and failure is imminent. Personally, I'm not a fan of RE's joints as well, but that's just my opinion. JJ's are the way to go. Excellent joint on and off the road.
I'm not
Pretty much every time there is a thread on asking for buying advice RE vs ?? the responses are RE is the lift to buy. If someone brings up the negatives you can guarantee the RE lovers will jump in and say it was a one-off or improper install.
Friends don't let Friends run Bosch
Pillswoj is offline   Reply With Quote
Unread 07-21-2009, 06:05 AM   #63
jawalterusmc
Green Machine
jawalterusmc's Avatar
I have the RE 4.5 superflex kit. It has been installed now for over one year and I have been off road (hard riding) only six times. I have had to replace both of the rear sway bar end links RE1155 because the bushings had disintegrated. I kept the old links in the hopes of finding some after market bushing to reinsert so that I could have another backup set in case of emergencies.
jawalterusmc is offline   Reply With Quote
Unread 07-21-2009, 06:20 AM   #64
RubiconRazorbac
RubiconRazorbac's Avatar
I would expect the LJ to "ride" a little better anyway. Has anyone had experience comparing RE-vs-Currie arms on the same platform?
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
KOH EMC thread: http://www.jeepforum.com/forum/f22/p...build-1476559/
RubiconRazorbac is offline   Reply With Quote
Unread 07-21-2009, 06:38 AM   #65
cgmrdc
1988 MJ Comanche
i destroyed the bushings i bought after a week of hard wheeling in Moab and CO... when i got home I called redrock... my new bushings are on their way free of charge! btw... ive ony had my current bushings since may... we shall see how long the new ones last. has anyone iunstalled them? how are they holding up?
cgmrdc is offline   Reply With Quote
Unread 07-21-2009, 08:00 AM   #66
glockster
glockster's Avatar
Perhaps.....but they're still the same arms installed at the same lengths and at the same angles. I've owned both and made my choice based on my experience.
Marco
Unread 08-03-2009, 03:03 PM   #67
miguelitojeep97
I just talked to Mike at Rubicon Express. Outstanding customer service! They are getting the newer bushings in stock.
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline   Reply With Quote
Unread 09-11-2009, 11:25 AM   #68
jcv400ex
Hmm, I'll have to go home and check mine now after reading this!
jcv400ex is offline   Reply With Quote
Unread 09-11-2009, 06:05 PM   #69
Tom Hartz
I received a new set (Free) from Rubicon Express, they are different. Put them in and all is good.
Tom
Tom Hartz is offline   Reply With Quote
Unread 09-11-2009, 10:56 PM   #70
jcv400ex
Passenger side bushings are cracked....I'll be calling Rubicon Express on Monday.....
Unread 09-18-2009, 02:10 PM   #71
glockster
glockster's Avatar
I'm leaving for Utah on Tueday morning. I'll report back any issues I have with new bushings. I've had no problems yet. This will be a good test.
Marco
Unread 09-24-2009, 08:07 AM   #72
TNeustadt
Same problem here, lift installed 4 months ago. Aprox 3000 miles, did some pretty tough wheelin', 3 or 4 times. Waiting on replacements currently. Don't even want to drive it since it got so bad. Upper and lowers. Do I need a press to do the replacement?
TNeustadt is offline   Reply With Quote
Unread 09-24-2009, 08:14 AM   #73
Greg_Volkman
You guys all have short arms with steep angles?
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Unread 09-24-2009, 08:28 AM   #74
jcv400ex
I have short arms
Unread 09-24-2009, 08:43 AM   #75
TNeustadt
3.5" super flex kit + upper adjustables
