Rubicon Diff Fluid Question - Page 2 - JeepForum.com
post #16 of 32 Old 07-21-2010, 11:19 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I might have misread my '04 manual but I did read that section yesterday out of curiosity after seeing this thread. I'll have to re-read it again later today to verify what I read.
Getting
Jerry Bransford is online now
post #17 of 32 Old 07-21-2010, 11:24 AM
-dirt-
The reason I asked if RogueSpear looked at the rear specs, or just the front, is because for the front Rubi D44, it does say 80W90 -or- 75W140 syn., if towing.
Let us know about the 2004 info!
-dirt- is offline
post #18 of 32 Old 07-21-2010, 11:27 AM
ajamison
ajamison's Avatar
1991 MJ Comanche
i didn't see anybody mention this but it was noted in the manual a few posts back, limited slip additive for the rear...
Jamison
ajamison is offline
post #19 of 32 Old 07-21-2010, 11:29 AM
Zen
Originally Posted by Jerry Bransford View Post
The front diff's viscosity doesn't need to change for towing because the front axle is not engaged when towing. The Rubicon's rear diff's recommended viscosity is 80W-90 unless you are towing, then the recommended viscosity becomes 75W-140.
I wouldn't have believed it either if I hadn't read it. Who tows in 4WD? What diference does trailer wieght make on a free spinning front axle? I guess that's why we have the engineers.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #20 of 32 Old 07-21-2010, 11:29 AM
anymanusa
wanna read this later.
anymanusa is offline
post #21 of 32 Old 07-21-2010, 11:30 AM
-dirt-
No additive is needed for the Rubicon. It has the "Tru-lok". The "Trac-lok" is the limited slip offered in some non-Rubi rear axles.
-dirt- is offline
post #22 of 32 Old 07-21-2010, 11:31 AM
Zen
If the fluid you buys says for use in limited slip diferentials it already has the modifier in the bottle. I've not seen a quality synthetic fluid that did not come with the friction modifier pre-installed. That's why you don't hear about it in a Rubicon specific thread. That and the whole trac-loc vs. tru-loc thing...
-Stick, splash one!
Zen is offline
post #23 of 32 Old 07-21-2010, 11:31 AM
ajamison
ajamison's Avatar
1991 MJ Comanche
oh i thought the rubicon rear axle had a limited slip and a locker... my mistake
Jamison
ajamison is offline
post #24 of 32 Old 07-21-2010, 11:32 AM
Jerry Bransford
Administrator
I think it's a screw-up and there have been errors in past FSMs, notably like when they mistakenly recommended a GL-5 gear lube for the AX-5 and AX-15 transmissions.
Getting
post #25 of 32 Old 07-21-2010, 11:53 AM
DivineKaos
I have had issues when towing starting on a hill (dirt road), and used 4WD Hi, I found it helped me get traction faster, and once I get going (or off the hill) I switch back to 2WD
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
post #26 of 32 Old 07-21-2010, 04:11 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
It does. It's a gear driven limited slip, not clutch...
Knuckelhead is offline
post #27 of 32 Old 07-21-2010, 04:12 PM
Jerry Bransford
Administrator
Which means it doesn't need the additive.
Getting
post #28 of 32 Old 07-21-2010, 04:24 PM
solarpower
If you look at the tags on your axles from the factory it will say
75W-140 on the rear tag...
and either 80w-90 or 75W-140 for the front depending on when it was made.
and to the OP:
DO NOT over-tighten your rear diff fill plug. The FSM says 30 ft lbs and it's wrong...you want to snug the plug and turn it about 1/4 to 1/2 turn...just so it does not leak. my plug seals at 17 ft lbs.
Over-tightening the fill plug will drive the magnet (on inside of plug) into your locker acuator and make bad things happen..very bad things.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #29 of 32 Old 07-21-2010, 05:06 PM
Srhmn8r
YEP. Learned that the hard way. Just wrap the threads of the fill plug with some teflon tape and tighten until snug.
03 Rubicon RE 3.5" and 1.25" JKS BL 35" BFG MT's
Srhmn8r is offline
post #30 of 32 Old 07-21-2010, 05:12 PM
BlackAura
I suddenly have the urge to go back and loosen off my plugs, I think I snugged them to 25 ft lbs....eep. Will I only notice this when it comes time to engage the lockers? Haven't been offroad yet, so I haven't had a reason to engage them.
BlackAura is offline
rubicon , differential , gear oil , recommendation , help , advice , TJ
04 Rubicon Diff Fluid surfride TJ Wrangler Technical Forum 11 04-13-2015 12:24 PM
Rubicon lockers and diff fluid kyjeep98 JK Wrangler Technical Forum 3 04-09-2010 09:10 AM
Rubicon Diff fluid capacity paultyler TJ Wrangler Technical Forum 5 03-01-2010 02:00 PM
rubicon diff fluid Bobski TJ Wrangler Technical Forum 3 12-13-2009 02:12 PM
Diff. Fluid Question dr_finklestein TJ Wrangler Technical Forum 3 03-16-2008 09:51 AM
