Rubicon Diff Fluid Question - JeepForum.com
post #1 of 32 Old 07-20-2010, 12:46 PM Thread Starter
skinpin
well - the more I read, the more confused I seem to get - Its an 04 Rubicon, I have both 80W90 and 75W140 here at my shop- what do you recommend?
skinpin is offline
post #2 of 32 Old 07-20-2010, 12:49 PM
-dirt-
DC recommends synthetic 75W140 for the Rubicon per the user's manual.
-dirt- is offline
post #3 of 32 Old 07-20-2010, 02:44 PM
BlackAura
I just went through this myself, and I found a few posts that specifically said use 75W-140 synthetic for the Rubicon Dana 44's w/ lockers.
So rather than possibly damaging my Jeep, I decided to just accept the extra cost and put in the synthetic fluid. Seems to be running good so far (changed it on Sunday though, so it's only been in there for 2 days).
If you want sources I can point you to a few articles / posts regarding the fluids.
BlackAura is offline
post #4 of 32 Old 07-20-2010, 04:03 PM Thread Starter
skinpin
Also, when the covers are off, should you do any cleaning? like hose everything down with brake clean, or is fluid change enough?
skinpin is offline
post #5 of 32 Old 07-20-2010, 04:25 PM
BlackAura
I had to pull the front cover off because it was leaking (or I guess "seeping"). I quickly learned why:
Didn't snap a "before" picture of the cover, but here's the diff itself:
The cover was really rusty at the bottom there as well. Thankfully most of the rust in the picture was on the old RTV liquid gasket, so the main case wasn't too bad.
After some cleanup:
The cover, after cleanup, you can still see some pitted areas where there was rust:
I've heard that some people will spray brake clean in...to be honest I didn't, just used a wire brush and some sandpaper to clean up the rusted areas that would seat up against the cover.
The back diff didn't have any issues, so I was lazy and didn't even pull the cover. Just drained the old fluid from the drain hole (on the right side of the diff at the bottom, when you're looking at the cover / fill hole) and put in the new stuff.
post #6 of 32 Old 07-20-2010, 09:24 PM Thread Starter
skinpin
Black Aura - thanks for the info - I'm a service writer at a German car repair shop, so I know how critical fluid/processes are - fairly new to the Jeep world - we worked on land rovers for quite awhile - i'm kinda into using factory products/oem parts as much as possible, even though i know most of the stuff is quite generic anyways - im probably going to use a BG product/ their diff fluid (75/140) - its what bmw dealerships put in the 3 and 5 series M cars - although what i really hear is it doesnt make too much a difference..... i just want my **** to last - from what the maintenance records look like, my rubicon has 53k and no diff fluid change - doesnt seem to be offroaded though - no mud/etc inside the framerails - im pretty sure it wasnt much more than a daily driver before i bought it last week
skinpin is offline
post #7 of 32 Old 07-20-2010, 10:37 PM
BlackAura
No problem, glad I could help! Congratulations on the purchase! I'm also a fairly new owner...I've only had my Rubicon for a month now, but I'm loving it so far. On that note, you may want to check into more information, or let other people chime in on this thread as well, I'm just going by the information I've researched myself (and I'm fairly new to this).
On the break-clean thing, I have heard of other people who will spray a lot in there, but I never did find out if that was only for the stock diffs. I was worried it may damage the lockers on the Rubicon, so I decided to just change it out.
post #8 of 32 Old 07-21-2010, 01:53 AM
RogueSpear2023
According to my FSM it says for the Rubicon D44s 80w90. Or if towing 75W140 Synthetic.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #9 of 32 Old 07-21-2010, 07:17 AM
-dirt-
Did you look at the specs for the rear axle, or just the front?
-dirt- is offline
post #10 of 32 Old 07-21-2010, 07:39 AM
glockster
Correct. As stated in the 2004 FSM. I believe the 2005 may state this different. I have both FSM's, I will check the 05 when I get home.
For the record, I run synthetic Mobil One front and rear. Just makes it easier.
Marco
glockster is offline
post #11 of 32 Old 07-21-2010, 07:42 AM
-dirt-
Hmm. In the 2005 FSM, it says 80w90 or 75W140 Synthetic, if towing, for Rubicon D44s for the front. For the rear Rubi D44, is only says 75W140 Synthetic.
-dirt- is offline
post #12 of 32 Old 07-21-2010, 07:49 AM
glockster
Hey dirt, that makes sense. I remember a slight difference between the 2 FSM's, I just couldn't remember the difference.
Marco
post #13 of 32 Old 07-21-2010, 09:42 AM
Zen
I just buy the 75W140 synthetic so that it's the same, but the live axles in our Jeeps are not too picky so the fluid choice is not that critical as long as you use quality stuff and keep the junk/water out.
I only use brake cleaner if I'm taking stuff apart (I like to stay clean...) or if it's really nasty inside (only happens when i work on other peoples rigs ).
BTW Dirt, the I'd bet the diference in spec between the front and rear have to do with loads and forces on the gears. Every time the Jeep moves the rear diff is under stress. 95% of the time you're in 2WD so the front simply spins freely so it needs less protection. The service interval on the front and rear is the same even though the front fluid should last much longer. My rear fluid always smells/looks worse than the front fluid when I swap.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #14 of 32 Old 07-21-2010, 10:05 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The front diff's viscosity doesn't need to change for towing because the front axle is not engaged when towing. The Rubicon's rear diff's recommended viscosity is 80W-90 unless you are towing, then the recommended viscosity becomes 75W-140.
Jerry Bransford is online now
post #15 of 32 Old 07-21-2010, 10:13 AM
-dirt-
That's not what the 2005 FSM or user's manual says. Its says 75W140 synthetic regardless:
-dirt- is offline
rubicon , differential , gear oil , recommendation , help , advice , TJ
04 Rubicon Diff Fluid surfride TJ Wrangler Technical Forum 11 04-13-2015 11:24 AM
Rubicon lockers and diff fluid kyjeep98 JK Wrangler Technical Forum 3 04-09-2010 08:10 AM
Rubicon Diff fluid capacity paultyler TJ Wrangler Technical Forum 5 03-01-2010 01:00 PM
rubicon diff fluid Bobski TJ Wrangler Technical Forum 3 12-13-2009 01:12 PM
Diff. Fluid Question dr_finklestein TJ Wrangler Technical Forum 3 03-16-2008 08:51 AM
