Quantcast rubicon D44 vs D60 clearance savings - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > rubicon D44 vs D60 clearance savings
Poison Spyder BFH Rear BumpersFront and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yo
Old 01-19-2009, 06:36 AM   #1
van1
I was wondering how many inches of clearance do you save by sticking with the stock rubicon D44 axle over a dana 60 axle. The D60s that come in trucks, not the high end expensive ones that can be bought.
van1 is offline   Reply With Quote
Old 01-19-2009, 09:49 AM   #2
rubiweeler
What size tires do you plan on using, do you need a 60. more info needed.
Superior axles doesn't honor their warranty. Don't buy from them.
rubiweeler is offline   Reply With Quote
Old 01-19-2009, 10:10 AM   #3
van1
I personally plan on running 35s. You see I have always ran full size trucks. My last truck was a dodge ram 3/4 ton truck, which I put 35s on it stock. The truck before that was a Ford SD which I had 40" ground hawgs on it(5.5"lift). I was trying to figure out the ground clearance between the 2 axles to see what size tires it would equal on the D44 vs D60. Basicly would a jeep, with 35s, have as much ground clearance as a D60'ed(or 14bolt or sterling 10.5) full size with 38" or 40"s.
Glock Forum
