Rubicon D44 Rear Axle Into TJ Sport - JeepForum.com
post #1 of 13 Old 02-11-2010, 02:05 PM Thread Starter
shay4au
2010 JK Wrangler
I will soon be swapping out my D35 rear axle in my '01 Sport with a Rubicon D44 that I'm buying from a friend. Besides having to get a 1310/1330 U-Joint and possibly having to shorten the driveshaft, does anyone know of any other issues that could arise? In particular, will I have any transfer case issues? It's my understanding that the Rubicons have different transfer cases so I was just curious. I've read where this thing should bolt right in with the possible DS problem, but nothing else other than possibly a new e-brake cable. Just trying to make sure I'm aware of all potential "surprises" before getting started! What about the difference in brakes from these models? Will this require new axle shafts or should it be good to go as-is? Any input will be appreciated!!!! Lift: 2.5" OME with 3/4" spacers and JKS 1.25" BL. Just throwing that out there. Thanks!
shay4au is offline
post #2 of 13 Old 02-11-2010, 02:28 PM
Fett
Mechanically Declined
Fett's Avatar
It won't work...just give me the D44 since it's junk to you now.
Just kidding. Bump to top because I'm interested in knowing these answers too. Your D35 has drum and the D44 should be disk. I wonder if you'll need different brake lines? The shafts should be just fine though.
99 TJ Sport I64L Manual 31x10.5 RE 3.5" Super Flex 1"BL 3.73 gears w/LockRite in front. Warrior Safari Rack.
"When you honestly believe you can compensate for lack of skill by doubling your efforts, there's no end to what you can't do".
|_
|T|
Fett is offline
post #3 of 13 Old 02-11-2010, 02:30 PM
jaminb
i belive the rubicons transfer case has a fixed yoke out put, if you dont have a SYE on your jeep now then you will have issue with the drive shaft.
jaminb is offline
post #4 of 13 Old 02-11-2010, 03:02 PM
MO2500
Are you going to re-gear your front D30 to 4.10? Because 4 wheel drive isnt going to work unless your axles are geared the same
Other than the issue with the driveshaft and e-brake cables it is my understanding that the axle will bolt right up. You just have to take care of gearing your front axle to match
Instagram: @omsmike
MO2500 is offline
post #5 of 13 Old 02-11-2010, 04:03 PM
loaderopp
Slip yoke or a drive shaft mod. a regear if you do not have 4.10 gears in the front.
Air compressor for the locker if the locker is in the d44. and maybe a track bar swaybar relocate.
Built not bought!!!
2005 Rubicon Unlimited, 5.5 inch custom long arm, 1 inch daystar body lift, River Raider Snorkel, Custom bumper/winch mount, sliders, tire carrier. 37x13.50 R17 Nitto Mudgraplers, Bushwacker flat fender. Custom 1/2 cab. Hyline hood vents. Custom tonnue cover and tool box. HID-X off road lights, LED driving lights custom rear bumper/m6000 rear monted winch.
loaderopp is offline
post #6 of 13 Old 02-11-2010, 04:12 PM
Benderff
Benderff's Avatar
It sounds like you have it figured out already. Like you said you will need parking brake cables if they don't come with the axle. The regular brake lines are the same. You might have to shorten your drive shaft, and you will need the U joint you mentioned. I would get the axle under then see if it needs to be shortend. It is a direct bolt in. The only thing you might look at is the sway bar nuts. They rust out easy. I had to fix them on my swap. Get the air pump for the locker if you can also.
http://www.jeepforum.com/forum/f9/ho...e-swap-901419/
Benderff is offline
post #7 of 13 Old 02-11-2010, 05:45 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
That's depends on what gears are in the D44, he didn't say it was stock?...
Knuckelhead is offline
post #8 of 13 Old 02-11-2010, 07:57 PM Thread Starter
shay4au
2010 JK Wrangler
Thanks everyone!! I will be re-gearing the front D30 to match this D44 that I'm putting in, so gears won't be an issue. I don't have a SYE and had hoped I could avoid having to get one. Sure hope thing thing goes right in with minimum issues other than the DS!! I appreciate all of the input!!
shay4au is offline
post #9 of 13 Old 02-11-2010, 08:30 PM
jdhallissey
You can use your drum ebrake cables still too. Your driveshaft will be a little tight. I did the same swap. You will be fine for a while but save up for a SYE and driveshaft.
jdhallissey is offline
post #10 of 13 Old 02-11-2010, 09:59 PM
loaderopp
Well i wish you the very best for your upgraded axle. good luck!
Built not bought!!!
post #11 of 13 Old 02-11-2010, 10:19 PM
Benderff
Benderff's Avatar
Sure if you want to make up some way to clamp them on. It is not a direct swap from drum to disc brakes. Personally I wouldn't trust the clamp method I have seen people do. I live on a hill and need my parking brake.
Maybe you could share with him how they will work since he will be asking that now.
Benderff is offline
post #12 of 13 Old 02-12-2010, 06:45 AM
MO2500
Unless some knucklehead re-geared their rubi to 3.07 then a re-gear in the front is still needed in this situation....
Instagram: @omsmike
MO2500 is offline
post #13 of 13 Old 02-12-2010, 10:18 AM
1SlowPoke
If you go with the CV DS you will also need adjustable upper control arms...
1SlowPoke is offline
Specs on rear axle for tj (00,sport) chadc84 TJ Wrangler Technical Forum 1 01-25-2010 08:25 AM
Rubicon D44 Axle Install into a TJ Sport shay4au TJ Wrangler Technical Forum 23 11-24-2009 02:59 PM
rubicon rear axle swap 00jeepred TJ Wrangler Technical Forum 10 10-30-2008 12:13 PM
Rubicon D44 Rear Axle Swap Today StvDiego TJ Wrangler Technical Forum 0 08-12-2007 07:09 PM
rubicon rear axle JSBlu974X4 TJ Wrangler Technical Forum 34 04-16-2005 11:01 PM
