rubicon axles on TJ - JeepForum.com
post #1 of 35 Old 05-06-2005, 04:24 PM Thread Starter
faster
rubicon axles on TJ
Do you have information about is it possible to fit the axles from wrangler rubicon on TJ
I have a very nice offer for the 2 axles and don`t know to take it or leave it
faster is offline
post #2 of 35 Old 05-06-2005, 04:30 PM
C2U5H
C2U5H's Avatar
as far as i've heard they should bolt right up...i'm pretty sure all the control arm mounts and everything are in the same position
~J
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #3 of 35 Old 05-06-2005, 05:02 PM
JSBlu974X4
all ya need is diff U joints, they run 1330 instead of 1310. if you have rear drum you should be fine with brakes but if they feel weird then you might need a proporting valve
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #4 of 35 Old 05-06-2005, 06:17 PM
Joel77
BTDT. Direct swap, just the 1330-1310 combo CV U-Joint.
Joel77 is offline
post #5 of 35 Old 05-07-2005, 03:52 AM Thread Starter
faster
some people told me that the wheels for rubicon are different
do you guys know anything about it
faster is offline
post #6 of 35 Old 05-07-2005, 04:22 AM
BACKROAD
BACKROAD's Avatar
The Rubicon wheels are 16" dia., but the bolt pattern is the same.
1956 Willys Flatfender....SOA, Buick V8, Turbo 350, locked both ends, wheelbase lengthened from 80" to 86", 35" TSL's on 15X12 Wheels...
1989 MJ.........4.0 with auto...2" BB and Rubicon tire PKG.
& a shiny new 2005 RED Rubicon Unlimited...RE3.5 Superflex and 33X12.50-15 MTR's and 15X10's. And a sad 10-13 MPG.......
4 WHEELING CAN BE AN ART WHEN APPLIED PROPERLY AND CARNAGE IS NOT A NECESSITY.......
BACKROAD is offline
post #7 of 35 Old 05-07-2005, 04:39 AM Thread Starter
faster
what about the hubs
are the rubicon hubs like the TJ`s or some havie duty thing ?
faster is offline
post #8 of 35 Old 05-07-2005, 06:10 AM
03jeeper78
03jeeper78's Avatar
You're gonna need the air compressor system for the lockers if you ever want to lock em too. That may be what you're thinking of when you're talking about heavy duty (locking?) hubs.
03jeeper78 is offline
post #9 of 35 Old 05-07-2005, 07:16 AM Thread Starter
faster
So the hubs on the front wheels are locked with compresed air
I thought only the locking diffs are doing that
faster is offline
post #10 of 35 Old 05-07-2005, 07:30 AM
CJM
An added benefit to the Rubicon axles, are that they have 4.11 gearing and have air lockers. The hubs on the axles are always locked....I think it is only the trans case that actually engages the 4wd.
Air lockers for example....make sure that both front tires are turning...........when the tire with the least amount of tracion would be turning without lockers.
From what I just read in the other posts, just buy the axles, get didderent u-joints and get the additional equipment if you want to engage in the air ockers......but I am sure the setup will work fine without the additional air locking equipment.
Others might be able to explain better...
CJM is offline
post #11 of 35 Old 05-07-2005, 07:36 AM
Fat_Man
I would love it if I could get ahold of some Rubi axles . . .
Wouldn't installing them and thuen setting up your own air, etc, for the lockers also bypass how the Rubi stock will only engage the lockers in 4 low only?
A hidden bonus?
Fat_Man is offline
post #12 of 35 Old 05-07-2005, 07:38 AM Thread Starter
faster
thenks guys you helped me alot
faster is offline
post #13 of 35 Old 05-07-2005, 08:54 AM
Lud04X
A hidden bonus?
Actually it's pretty easy to run the stock Rubi lockers in 4-high with an easy bypass as well so I've heard.
Khaki 2004 Wrangler X
OME HD Kit,JKS BMML,1.25 JKS BL, adj. control arms
RE Generation II Quick Discos
35x12.5x15 Goodyear MTR's w/ Kevlar, MT Classic II's
D44 rear axle w/ ARB, alloy shafts, 4.56 gears
Dana 30 with ARB, 4.56 gears, alloy shafts and ujoints
Lud04X is offline
post #14 of 35 Old 05-07-2005, 10:35 AM
Fat_Man
Yeah, I have heard about the bypass for the stockers. But I was mainly meaning for non-rubi owners who went junkyard diving and pulled out a pair of Rubi axles, that when they hooked it up, that could be a hidden plus. Minor detail, really.
Fat_Man is offline
post #15 of 35 Old 05-07-2005, 03:56 PM Thread Starter
faster
Just got some info ... a MECHANIC told me that the rubi axels are widther than the axels of TJ
do you know anithing about that
faster is offline
JK Rubicon Axles/D44 Vrrooom JK Wrangler Technical Forum 9 11-30-2008 07:51 AM
JK rubicon axles to TJ jappe TJ Wrangler Technical Forum 1 09-19-2008 10:23 AM
Rubicon axles on my tj kcchapman TJ Wrangler Technical Forum 20 07-06-2008 08:12 AM
Rubicon axles jappe TJ Wrangler Technical Forum 4 06-23-2008 12:43 AM
Rubicon Axles on a TJ? GA TJ TJ Wrangler Technical Forum 21 07-16-2005 06:08 AM
