Rubicon axles? - JeepForum.com
post #1 of 6 Old 01-27-2008, 08:15 PM Thread Starter
Anti-bling
Rubicon axles?
I can no longer use O/D (over drive) on the highway. I have 33's and stock 3.73(dana 44 and 30)...i think is what they are, and as soon as O/D kicks in, the jeep quickly loses momentum and speed. Its frustrating. I know the rubicon axles have 4.10s, would this be a large enough adjustment? Plus they have lockers. Are they hard to find? Is the swap hard? expensive? any help would be great!
'04 Wrangler Sport: Khaki, D30/D44, 2.25" BB, JKS 1.25" BL, OME Coils, Fabtech style front bumper, Herculined tub, Hi-Lift, Jerry Can, HUNSAKER ENVY seats, Flowmaster 40, CAI, Performance TB, 33x12.5's, Defender basket with SRC soft top rack, Lite Dot, CJ Tailgate, Rear Stinger.
Anti-bling is offline
post #2 of 6 Old 01-27-2008, 08:19 PM
snakester14
It would most likely be cheaper to keep your current set up and just regear/Lock it.
just my 2 cents.
1998 ZJ 5.2/2inch bb/265 a/ts/Flowmaster SOLD
1996 Stock XJ 4.0/ax-15/231 Traded
1998 4.0/ax-15/231 TJ on 33s SOLD
snakester14 is offline
post #3 of 6 Old 01-27-2008, 08:21 PM Thread Starter
Anti-bling
to 4.10's? thanks for the reply
post #4 of 6 Old 01-27-2008, 08:29 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
3.73 to 4.10 is a 10% change, not much really.
For your setup, I'd go with 4.88.
Your 4 speed has a tall OD ratio of 0.69:1. This means you can run low axle gears and still be right within the acceptable RPM range for cruising on the highway.
With 4.88 gears and 33" tires, you'll turn about 2,500 RPM at 70 which is perfect. You'll have great low end power too.
Wheelin98TJ is offline
post #5 of 6 Old 01-27-2008, 08:52 PM
That1guy
That1guy's Avatar
2007 WK
It would alot easier to regear than to buy new axels, unless you wanted a front 44 and the locker. Then you can just regear that too i guess. Anyways like said 4.88's are nice.
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
post #6 of 6 Old 01-28-2008, 12:20 AM
Bigbob
Bigbob's Avatar
With an auto you want 4.88. Maybe 4.56 if you don't do hills. 4.10/auto/33" tires= no bueno. I got a 6 speed on my rubi so I did not have to regear.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
Rubicon Axles? Fred007 YJ Wrangler Technical Forum 12 10-01-2009 08:21 PM
JK Rubicon Axles/D44 Vrrooom JK Wrangler Technical Forum 9 11-30-2008 08:51 AM
Rubicon axles on my tj kcchapman TJ Wrangler Technical Forum 20 07-06-2008 09:12 AM
Rubicon axles ?? gtex TJ Wrangler Technical Forum 1 09-13-2005 01:35 AM
rubicon axles on TJ faster TJ Wrangler Technical Forum 34 05-12-2005 12:13 AM
