Rubicon axles - JeepForum.com
post #1 of 5 Old 01-06-2008, 09:06 AM Thread Starter
jappe
Rubicon axles
How hard is install these axles to TJ?
What are biggest problems?
http://www.4wd.com/productdetails.aspx?partID=15586
http://www.4wd.com/productdetails.aspx?partID=15587
Just do it
jappe is offline
post #2 of 5 Old 01-06-2008, 09:35 AM
19OlllllllO41
19OlllllllO41's Avatar
Rather difficult, thats the reason no one around here has done it (or almost no one that ive heard of). Nothing will line up, all brackets would need to be replaced/moved, bolt pattern for wheels is different so you would need spacers, new axle shafts, or new rims with the JK bolt pattern, and the whole axle is wider than a TJ axle. And if I remember correctly, the lockers work with some type of electric impulse setup that is not easy to make work on a TJ, compared to the TJ Rubi lockers which are locked by a simple air pump. IMO dont waste your time, just buy axles set up for a TJ.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #3 of 5 Old 01-06-2008, 09:41 AM
abnormal
Platinum Member
abnormal's Avatar
I think those axles have mounts for the jk. You would have to cut the mounts off and have tj mounts welded to it. You can get axles already setup for a tj for more money with an ARB airlocker installed and the gears you want. You would just have to figure out the difference in price. 4wheelparts has free shipping on axles right now.
abnormal is offline
post #4 of 5 Old 06-23-2008, 12:36 AM Thread Starter
jappe
August petersen's 4WHEEL & ofroad has article to swap these axles to grand cherokee.
Lockers just need 12v to work.
Only modification to front axle was moving the upper coil spring mounts. Other topic I read that Grand Cherokee (old) has same front axle with TJ wrangler.
So, to put this front axle to TJ is moving the upper coil spring mounts. No modifications to axle.
Is that true?
Just do it
jappe is offline
post #5 of 5 Old 06-23-2008, 12:43 AM
mJUSTINm
http://www.4wdandsportutility.com/te...xle/index.html write up from 4wd&su mag about putting those axles in a yj just in case you havent seen it
mJUSTINm is offline
Rubicon Axles? Fred007 YJ Wrangler Technical Forum 12 10-01-2009 07:21 PM
JK Rubicon Axles/D44 Vrrooom JK Wrangler Technical Forum 9 11-30-2008 07:51 AM
Rubicon axles? Anti-bling TJ Wrangler Technical Forum 5 01-27-2008 11:20 PM
Rubicon axles ?? gtex TJ Wrangler Technical Forum 1 09-13-2005 12:35 AM
rubicon axles on TJ faster TJ Wrangler Technical Forum 34 05-11-2005 11:13 PM
