Rubicon Axles - JeepForum.com
post #1 of 11 Old 02-18-2014, 02:44 PM Thread Starter
chrislower
Rubicon Axles
I have a chance to buy the front and rear axles off a TJ Rubicon with the 4.56 gears and the original air lockers. I am unclear on the year model for my 00 TJ. he is asking 2k for the pair. They look to be in good shape. Very new to this arena, wanted some input if this was a good deal or not?
Thanks,
CL
chrislower is offline
post #2 of 11 Old 02-18-2014, 02:54 PM
Jeepsr4me
sounds like a good deal to me. Are the covers where you can look inside? why is he selling
Jeepsr4me is offline
post #3 of 11 Old 02-18-2014, 02:55 PM
cbrant
Assuming you have stock Dana 30/35 with factory gear ratio and plan on going with large tires, I would say yes definitely. In fact, I'd buy them anyway because I've never seen a set for 2k. Generally $3000+ when they pop up near me.
cbrant is offline
post #4 of 11 Old 02-18-2014, 03:31 PM
biffgnar
biffgnar's Avatar
Are you sure 4.56 gears?
2k is a decent price based on what they typcially go for.
Dakar Style Rally Raid in North America: www.sonorarally.com
biffgnar is offline
post #5 of 11 Old 02-19-2014, 10:34 AM Thread Starter
chrislower
I went by and looked at them yesterday, you are correct they do have the original 4.10 gears in them and he ended up going back on his original price and went to 1,500. Still probably going to get if i can't find elsewhere.
Thanks for the info.
CL
post #6 of 11 Old 02-19-2014, 10:59 AM
cbrant
$1500?! Buy them! If you don't want them, put them back on Craigslist.
cbrant is offline
post #7 of 11 Old 02-19-2014, 11:51 AM
rideraa
1500 is about half price of the going rate or better as stated before.
Try and get the oem pumps (one for each axle). Each one is about the size your fist.
Try and get parking brake cables.
Rear axle will be disk, get disks, calipers, disc brake rear brake lines are different also .
But none of those would be a deal breaker at 1500 unless your planning tires bigger then 35 or maybe 37.
"CHEAP HEAP" TJ, 4.0, 32rh, 231, built D44's, 37s etc.
"George 4man" CJ7, 304, 727, D300, C/O rear w/ stretch, built D44's (4 now) on pane :).
rideraa is offline
post #8 of 11 Old 02-19-2014, 12:01 PM
biffgnar
biffgnar's Avatar
Originally Posted by rideraa View Post
Only the rubi axle had rear disks.
Nope.
And before everybody gets too worked up, I'm guessing he meant $1500 each. How does it make sense otherwise if the original price was $2000 for the pair and the seller "went back on his original price". $3k for the pair is in the zip code of normal sales for these, although you do see them go for more.
biffgnar is offline
post #9 of 11 Old 02-19-2014, 12:03 PM
catmechanic
If you don't want them, send me the info. I can have them shipped to my dock for next to nothing and make $ on them. I already have a set in my 2001 and they've been great. I run 4.56's and 35's on alloy USA shafts and never had a single issue.
catmechanic is offline
post #10 of 11 Old 02-19-2014, 12:07 PM
watsoc08
I would grab the cash and get over there and get this deal done ASAP! That is a great deal and you will enjoy those axles a lot compared to your current setup.
watsoc08 is offline
post #11 of 11 Old 02-19-2014, 12:26 PM
stump1
to the op you do have a 6cyl right?
MY RIG: http://i78.photobucket.com/albums/j87/ramburger/a0fcb769-5e55-4a62-8426-cb7cce41c0c2_zpsccea3c78.jpg
stump1 is offline
differential , lockers , rubicon
