Rubicon Axles..... - Page 3 - JeepForum.com
post #31 of 34 Old 08-12-2010, 09:49 AM
rideraa
They say the rear locker is a bit weak due to the LSD .. I usally wheel with the rear locked as from what I have learned is it is most vulnerable when open. The common recomendation is to replace the rear locker with a rubi front locker and give up the LSD ...
I guess if mine breaks I might go to ARB ...
"CHEAP HEAP" TJ, 4.0, 32rh, 231, built D44's, 37s etc.
"George 4man" CJ7, 304, 727, D300, C/O rear w/ stretch, built D44's (4 now) on pane :).
rideraa is offline
post #32 of 34 Old 08-12-2010, 11:18 AM Thread Starter
mjonesjr
Oh yea, the 4.10's will be a HUGE difference over the stock gearing. It was capable and fun with the stock gearing. I bet it would be a beast with the 4.10's and the lockers. There was a few times when we took it out the first time that a locker would have helped a lot.
What are the 30 & 35's worth? They are in good shape.
I wont be off road with the locker unlocked.
mjonesjr is offline
post #33 of 34 Old 08-12-2010, 01:43 PM
rideraa
I don't know, I sold mine cheap to a friend, like $100 for both ... I keep the front calipers.
I saw on another board someone wanted $300 for a complete rear and another poster thought that was not to bad ... I would think the front 30 would be worth less. $200 to $400 range for the pair (30-35 @ 3.07, open) maybe.
If you hear any squeaking out of those front outter "U" joints change them asap ... I busted both sides pretty quickly, both after a day of wheelin.
It was like the next time I stressed them a couple days later. Seems like after you beat on them some the caps move a bit and next time they get pushed they pop out Both did not break the same day but weeks apart. They did squeak though when wet so they warned me, . I was runnin 35's
I ended up with RCV's front shafts yowee ($) those shafts do wheel smooth
rideraa is offline
post #34 of 34 Old 08-12-2010, 01:45 PM Thread Starter
mjonesjr
I will probably offer them up for $300 for the pair. I don't see why they are not worth that. Shoot, I could probably get that much in scrap for them.
Thanks for the info on the u-joints. I will keep my ears open for the squeek.
mjonesjr is offline
axle , swap , rubicon , d44 , dana 44 , locker , tj , wrangler
Rubicon Axles? Fred007 YJ Wrangler Technical Forum 12 10-01-2009 07:21 PM
Rubicon axles jappe TJ Wrangler Technical Forum 4 06-23-2008 12:43 AM
Rubicon axles? Anti-bling TJ Wrangler Technical Forum 5 01-27-2008 11:20 PM
Rubicon axles ?? gtex TJ Wrangler Technical Forum 1 09-13-2005 12:35 AM
rubicon axles on TJ faster TJ Wrangler Technical Forum 34 05-11-2005 11:13 PM
