Rubicon Axles..... - JeepForum.com
post #1 of 34 Old 08-04-2010, 12:35 PM Thread Starter
mjonesjr
Rubicon Axles.....
I havea '97 TJ with a 4" lift. I have a chance to get a set of '06 Rubicon axles. I am wanting to swap in these axles with the factory lockers and 4.10 gears in my '97.
Is there any problems doing this swap as far as bolt in axles?
What about getting the lockers to work?
mjonesjr is offline
post #2 of 34 Old 08-04-2010, 12:40 PM
dcope17
Get the pumps with it and then wire them in yourself. I'm sure there is a write up for that floating around here somewhere.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #3 of 34 Old 08-04-2010, 12:42 PM
BriansCJ
1994 XJ Cherokee
Make sure you get the pumps with the axles.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #4 of 34 Old 08-04-2010, 12:43 PM
njmjeep
grab his t-case and driveshaft also
njmjeep is offline
post #5 of 34 Old 08-04-2010, 12:43 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
they will bolt right in with the following conditions -
you'll need to change the front and rear driveshaft yokes. Rubicon's use 1330 u-joints...all other TJ's use 1310.
rubi air lockers run on 3-5psi, easiest thing to do would be buy a set of rubicon pumps, mount them under the hood and wire them up to dash switches.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 34 Old 08-04-2010, 12:43 PM Thread Starter
mjonesjr
Pumps?
I have an air compressor and holding tank now.
mjonesjr is offline
post #7 of 34 Old 08-04-2010, 12:44 PM
-dirt-
Pumps?
Rubi lockers are air-driven.
-dirt- is offline
post #8 of 34 Old 08-04-2010, 12:44 PM
Unlimited04
Pumps?
do you have a precision regulator and actuator capable of maintaining 3-5 psi?
the stuff to make your 125-150psi compressor work would cost in the neighborhood of $100-200. might as well just grab his pumps and wire them up for $5.
Useful Write-Ups:
Funny:
post #9 of 34 Old 08-04-2010, 12:47 PM
BriansCJ
1994 XJ Cherokee
Also your rear driveshaft will need an adapter u-joint.
If you dont use the right PSI, you will blow the seals in the lockers.
- Slow
BriansCJ is offline
post #10 of 34 Old 08-04-2010, 12:52 PM
Pillswoj
The rubicon lockers require low pressure (5 psi?) If you don't grab the actually rubi pumps you will need to regulate the air supply.
Friends don't let Friends run Bosch
Pillswoj is offline
post #11 of 34 Old 08-04-2010, 01:15 PM
Sundowner
If it's a totaled vehicle, grab the compressor wiring for them as well. That way you get the factory switches.
Sundowner is offline
post #12 of 34 Old 08-04-2010, 01:26 PM
snowrydr01
like stated, get the axles, tcase, and pump, instant rubi
snowrydr01 is offline
post #13 of 34 Old 08-04-2010, 01:29 PM
-dirt-
Would he need to change his skid set-up to run the larger tcase? Perhaps a body lift?
-dirt- is offline
post #14 of 34 Old 08-04-2010, 01:29 PM
Deacon
Shining Adonis
Deacon's Avatar
Obviously you'll want to verify that the axles are straight and unharmed, that the driveshafts are good, that the transfer case is good, that the locker pumps are good, etc.
As -dirt- mentioned, you'll probably also need to notch your skidplate or otherwise modify your mounts to handle the larger 241 transfer case. There are threads on here about swapping a 241 into '97-'02 TJ's.
Deacon is offline
post #15 of 34 Old 08-04-2010, 01:58 PM
472cid
pm if you have questions but i have a rubi 241 rubi axles and rubi driveshafts in my 97 and axles just bolt in but definately get the locker pumps and if you want i can tell you how to wire some contura rocker switches so the light comes on when axles locks. I would grab all but the six speed trans and run
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline
axle , swap , rubicon , d44 , dana 44 , locker , tj , wrangler
Rubicon Axles? Fred007 YJ Wrangler Technical Forum 12 10-01-2009 07:21 PM
Rubicon axles jappe TJ Wrangler Technical Forum 4 06-23-2008 12:43 AM
Rubicon axles? Anti-bling TJ Wrangler Technical Forum 5 01-27-2008 11:20 PM
Rubicon axles ?? gtex TJ Wrangler Technical Forum 1 09-13-2005 12:35 AM
rubicon axles on TJ faster TJ Wrangler Technical Forum 34 05-11-2005 11:13 PM
