rubicon with auto trans questions - Page 2 - JeepForum.com
post #16 of 25 Old 07-20-2010, 09:26 PM
popeyesides
popeyesides's Avatar
I have 5.13's and 33's and this is the perfect gearing. I am in Ouray, Co. right now wheeling for a week. I drove from Dolores to Telluride at 60 mph with cruise on running 2200rpm in OD without it down shifting then to Ouray with cruise on the whole way at altitude. If I go to 35's I will put 5.38's in. 4.1 t-case is way low now but that is why I put in a Rubicrawler in it last month to have 2.72 low which is perfect for most of my wheeling. When I got to Ouray I shot all over the tranny and lines with my IR gun and nothing was hotter than 182 degrees. I just turned 16k on the ticker. Hope this helps. BTW Unlimited 04 I am still going to get to the Rubicrawler right up when I get home from trip.
popeyesides is offline
post #17 of 25 Old 07-20-2010, 09:31 PM
LuckRider
LuckRider's Avatar
You can't do 5.38 without new lockers, so you might as well go for 5.89.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #18 of 25 Old 07-20-2010, 09:41 PM
popeyesides
I know, I will have Rubi lockers for sale.
post #19 of 25 Old 07-21-2010, 01:35 PM Thread Starter
cragrat
thanks for all the replies, sounds like i have some more thinking and research to do. i currently have 4.56 and 33's and have never lost a "battle" unless clearance becomes an issue. this jeep i'm looking at is just so badass i really wnt to grab it up. maybe ill get it and just keep on with 33's.
cragrat is offline
post #20 of 25 Old 07-21-2010, 02:48 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I may want your front locker when it becomes available and if it is cheap enough, please let me know when that happens if you think about it.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #21 of 25 Old 07-21-2010, 08:32 PM
pwmac
ruby gears & auto
Info:
2 rubis autos both have 35s one has 5.13 the other has 4.88. The 5.13 gets better fuel econoimy and flys up the passes to Silverton a lot faster.
Yes. Put the front stock locker in the rear to get rid of the lsd then put manual hubs and a detroit locker in front. Highly recomended by several hard core rub drivers, but to pricy for me. The manual hjubs are supposed to improve highway mileage??
Auto - yes, for sure. I sure think its designed different that any other auto I have had. Seems to work fine. I miss the manual converter lockup that we all use on the GM and Ford autos.
Paul
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #22 of 25 Old 07-21-2010, 08:52 PM
kuruma
So is there any other transmission that any have mated with the 4.0 that works better? With all the conversions going on out there I'd expect someone has been using another tranny other than a Jeep unit.
kuruma is offline
post #23 of 25 Old 07-21-2010, 11:16 PM
LuckRider
LuckRider's Avatar
AW4 as found in most Cherokees.
Support Our Troops!
JFI Member #7:
post #24 of 25 Old 06-18-2012, 07:30 PM
fixwithabullet
Originally Posted by Jerry Bransford View Post
Not sure what you're saying there but all Jeep automatics have an external automatic transmission cooler including the 42RLE and the 32RH it replaced. And when the axles have been regeared to a more appropriate lower ratio, the 42RLE is fine on the highway. Its overdrive ratio is just so steep that it needs a lower axle ratio to raise the engine rpms up to where the engine runs better.
If I was buying another Rubicon as I did a few months ago, I'd go with the automatic every time.
this comment keeps me relaxed about my rubis auto
fixwithabullet is offline
post #25 of 25 Old 06-19-2012, 06:48 AM
danb303
OP Keep in mind that Unlimited04 is in Denver...LOL You won't have to deal with the same elevation and mountains that he does.
I have a 05 Rubi auto and with 410 gears it can be somewhat frustrating. I will eventually upgrade to either 488 or 513. Just keep in mind that this tranny has the tallest OD that Jeep ever put in a Wrangler... well I'm not sure about the JK's?
danb303 is offline
transmission , tranny , auto , automatic , sye , drop , gears , rubicon , tj , wrangler
Rubicon auto trans./engine braking xinys JK Wrangler Technical Forum 1 05-27-2009 08:23 AM
2003 Rubicon Manual to Auto trans swap Rubicon Runner TJ Wrangler Technical Forum 3 06-03-2007 03:28 PM
Auto Trans Questions Thug Nasty TJ Wrangler Technical Forum 18 10-13-2006 07:54 PM
05 unlimited rubicon auto trans drharkey TJ Wrangler Technical Forum 6 03-01-2006 04:35 PM
Auto-Trans questions Roughneck TJ Wrangler Technical Forum 5 04-21-2003 06:01 PM
