Rubicon already lifted, but how much? - JeepForum.com
post #1 of 17 Old 03-11-2012, 07:14 PM Thread Starter
BioTex
1979 CJ7
Just bought an 06 and I'm trying to sort out exactly what lift I have. The tires are Pro Comp LT305/70R16. I believe that equates to 33's. They are brand new. The shocks and steering stabilizes are labeled as Rough country, so I'm assuming the lift is also Rough Country.
I have measure the transfer case drop as 1 1/2".
The trac-bar mount was redrilled.
New/longer sway bar disconnects.
Looks like the oem brake lines as well as the drive shafts. So, i'm wondering how to tell how many inches it is lifted?
Here are some pictures of most components.
lower-control-arm.jpg   rear-driveshaft.jpg   shocks-rc.jpg   sway-bar-connect.jpg   track-bar-redrill.jpg
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #2 of 17 Old 03-11-2012, 07:19 PM
STIFLER
well you are running 33s so without seeing a full shot of the rig and seeing rough country I am going to roll the dice that it is a 4" lift.
0311/2531 USMC YUT
STIFLER is offline
post #3 of 17 Old 03-11-2012, 07:37 PM
rchase559
Check here for measuring lift height.
http://www.jeepforum.com/forum/f9/fa...7/#post6077636
Then look at this and fix your front track bar mount.
http://www.jeepforum.com/forum/f9/br...racket-905624/
rchase559 is offline
post #4 of 17 Old 03-11-2012, 09:52 PM
2003RubiBlue
Yup Rough Country 4'' lift.
Will work for Jeep parts...
2003RubiBlue is offline
post #5 of 17 Old 03-11-2012, 10:58 PM
TJRHD
looks like the same arms I had on my rc 4 inch
NOT A HATER
TJRHD is offline
post #6 of 17 Old 03-12-2012, 07:04 AM Thread Starter
BioTex
1979 CJ7
I wanted to include a shot of the Jeep, but it got too dark out and the picture didn't come out well enough. Will post later today.
Thanks for those links! I'm an old school CJer, and am trying to absorb the new to me coil suspension basics. Lots of reading.... I did peruse the FAQ's section, but missed that chart. Excellent.
Thanks for helping to confirm what I wanted to hear.
Again, thanks all!
Currently:
BioTex is offline
post #7 of 17 Old 03-12-2012, 08:38 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
That's the old style 4" RC lift.You might want to upgrade those shocks for a better ride.I'd also ditch the t case drop for a MML and much smaller drop (or a SYE).
TheBoogieman is offline
post #8 of 17 Old 03-12-2012, 03:40 PM Thread Starter
BioTex
1979 CJ7
Funny you mention those two items! Logged on to complain/research two things.
Now that I have a whole 15 miles logged on the Jeep, I found out that the ride is very stiff or rough. I'm attributing most of it to the shocks. Any recommendations on a smoother ride. Afterall, that's why I purchased this TJ. If I want rough, i'll drive the CJ...
The second thing is the gear shifter. It pops out of reverse a lot. I got to looking at it, and see that the lowering kit caused the shift lever to hit the console housing. This won't let the lever properly mesh into reverse all the way.
Still trying to figure out a fix. I suppose 1/2" less of a lowered transfer case would do that. So would modifying the console housing, but not an easy thing looking at it. I'll look into MML but not sure what it is. Mile Marker???
Edit: Motor Mount Lift. Got it!
Currently:
BioTex is offline
post #9 of 17 Old 03-12-2012, 03:49 PM
flying_bosun
Motor mount lift.
If you have 4" of lift and stock brakelines, you probably want to replace 'em with YJ hoses.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #10 of 17 Old 03-12-2012, 03:59 PM Thread Starter
BioTex
1979 CJ7
Ok, so I have a 1 1/2" T.C. lowering kit. Is it better to go with a 1" MML? Do I still need a T.C.L.K. if I Use M.O.R.E. MML?
Are there any issues with the fan hitting the radiator or hood clearance issues? I figure not, but want no surprises. I have to get this Rubicon driveable by Easter. It is marginal IMO as it is.
Currently:
BioTex is offline
post #11 of 17 Old 03-12-2012, 04:04 PM
flying_bosun
How's the steering? I ask because of the TB re-locate on the axle side.
― Ron Paul
post #12 of 17 Old 03-12-2012, 04:10 PM Thread Starter
BioTex
1979 CJ7
You talking about the redrilled hole?
The TJ seems to steer nice enough. Unfortunately, I never had a chance to drive it stock, so nothing to guage it by. I have a friend who has the exact same Jeep, but he is on a sailboat in the V.I. right now drinking pina coladas...
Currently:
BioTex is offline
post #13 of 17 Old 03-12-2012, 04:46 PM
Gary2
check for a drop pitman , usually people who buy that kit don't know any better and install the DP also. Replace with the OE and reset toe in .
Gary2 is offline
post #14 of 17 Old 03-12-2012, 04:51 PM Thread Starter
BioTex
1979 CJ7
Gary,
Thanks for thinking about that. The pitman arm is original.
I'm wondering if I should just replace the TCL kit with a 1" kit. That should clear the shifter lever problem up, but not kill the rear drive shaft until I can replace it. $$$
Currently:
BioTex is offline
post #15 of 17 Old 03-12-2012, 06:47 PM Thread Starter
BioTex
1979 CJ7
I have a Rubicon, so I don't need the SYE correct? Just a Double Cardan shaft?
Currently:
BioTex is offline
Rubicon: Lifted or not? centerfireman TJ Wrangler Technical Forum 10 08-24-2010 10:09 PM
06 Rubicon - Is it lifted any? etgunner Wrangler General Discussion 9 07-18-2008 05:06 PM
New lifted Rubicon vibrations... rmontgomery2006 TJ Wrangler Technical Forum 8 03-31-2007 11:23 PM
Rubicon lifted? franco802 TJ Wrangler Technical Forum 10 11-13-2003 07:22 PM
Lifted a Rubicon? bigusdadius TJ Wrangler Technical Forum 11 11-05-2003 09:08 PM
