rubicon 241 oil leak maybe - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > rubicon 241 oil leak maybe
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!
Unread 01-25-2009, 01:29 AM   #1
rubicon1000
i got under my jeep the other day and noticed a small oil slick on the tub above my flange from my tc to my rear drive shaft. but nothing around the flange is wet. what could this be i have done searchs for the seal but have come up dry just alot about the 231 tc.
'12 unlimited sport S, 3.73, trac loc, towing package, rubicon unlimited springs and shocks
SOLD 03 Rubicon , nv 3550 ,4'' RC lift ,1'' RC MM lift, 1.25'' body lift, HD rear bumper, hummer snorkel cap with buick airbox and custom piping, 265/75 r 16 tread wright retread mud tires on stock rubicon wheels, smitty built 8k winch, cobra cb radio, rrc front bumper, pre-runner rear bumper, HID headlights in Hella housings
rubicon1000 is offline   Reply With Quote
Unread 01-25-2009, 01:37 AM   #2
472cid
u joint going bad maybe or seal only leaks when you are up to speed?
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline   Reply With Quote
Unread 01-25-2009, 01:41 AM   #3
rubicon1000
i dont know when it leaks i just know when i got back from driving today i looked under and saw it. im going to clean it off and see if i see it again
