Rubi swap / Axle swap (merged) - JeepForum.com
post #1 of 6 Old 06-10-2010, 10:06 AM Thread Starter
tjmike
I have a 2000 tj that I am going to put 2005 Rubi 44's and t/c.I have both driveshafts from the 2005 donor.Is there any thing thats going to be a *****? Feedback would be great if you have done this already..
tjmike is offline
post #2 of 6 Old 06-10-2010, 11:53 AM
biffgnar
biffgnar's Avatar
Do searches in TJ Tech. One search for the axle swap and one search for the TC swap. Lots of threads.
biffgnar is online now
post #3 of 6 Old 06-10-2010, 12:51 PM Thread Starter
tjmike
axle swap
I have a 2000 tj.I have purchased 2005 rubi. 44's t/c and drive shafts.Has anyone done this to there ride and if so,is there anything I should be aware of. Thanks looking for some feedback....
tjmike is offline
post #4 of 6 Old 06-10-2010, 12:58 PM
Niceface
hundreds have done these swaps before. Fill out your profile, and use the search button for hundreds of write ups on both the axle and t- case swaps.
Niceface is offline
post #5 of 6 Old 06-10-2010, 01:01 PM
Benderff
Benderff's Avatar
Hopefully you can find this thread again instead of starting the same one every hour. The axles are a direct swap. The TC will take some work. Like said above, and the other thread you started an hour ago try a search on here and google.
Benderff is offline
post #6 of 6 Old 06-10-2010, 01:04 PM
Coils Rule
need the air pumps for the lockers or if you have existing OBA you need to research proper PSI I think it's only 5psi and plumb that in.
Other than that it should be a cinch. I have no idea if that T/c will bolt up to that tranny make sure you verify.
Coils Rule is offline
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
would axle swap be ecomomical? (merged) backyardcrawler TJ Wrangler Technical Forum 18 03-22-2009 12:29 AM
Rubi axle swap RuffTJ TJ Wrangler Technical Forum 6 02-16-2009 08:16 AM
03 Rubi D44 Front & Rear Axle Swap into 97 TJ questions Poobah TJ Wrangler Technical Forum 8 10-20-2008 03:05 PM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
