Rubi gears Non rubi housing - JeepForum.com
post #1 of 1 Old 07-27-2010, 08:34 PM Thread Starter
goce61
Just blew my rear pinion gear in my 05 LJ with 3.73 L/S rearend. since I'm running 33's, I have the chance to upgrade to 4.10's, with a Dana 30 open gear set and a Rubicon locker with pump and 4'10's.
Can the Rubi locker be installed into a non-Rubi axle housing witn minor modifications??
Or will the 4.10 Rubi ringgear and pinion fit on the stock 3.73 Limited slip carrier?
goce61 is offline
rubicon , tj , wrangler , gears , housing
D44 Rubi Gears gmd JK Wrangler Technical Forum 10 02-25-2009 12:14 PM
05 Rubi gears on an 06 non-Rubi? surfcaster TJ Wrangler Technical Forum 7 02-13-2007 06:29 PM
4.88 gears with 33s on a Rubi toastervet TJ Wrangler Technical Forum 20 09-23-2006 07:37 PM
Help...Rubi D44 Housing Plugs Viet15philong TJ Wrangler Technical Forum 11 12-14-2005 01:48 PM
How to plug hole for air locker in Rubi housing? DesertX04 TJ Wrangler Technical Forum 4 08-30-2005 08:03 PM
