Rubi Front Axle Leaking, while apart... - JeepForum.com
post #1 of 5 Old 02-15-2013, 08:08 AM Thread Starter
STi954
I have a 2005 Rubicon with 80,xxx miles. My front passenger axle seal is leaking. I am going to change both driver and passenger, figured that'd be a good idea. My question is, while I have my shafts and locker and everything apart or out is there anything else you would recommend replacing/ changing while it is all apart?
Thanks in advance
Yellow Jeep Club #954
K.C.C.O.
STi954 is offline
post #2 of 5 Old 02-15-2013, 08:21 AM
NotURMailman
Not really, but a good inspection and cleaning are in order.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 5 Old 02-15-2013, 09:24 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I would install outer tube seals and clean the inside of my tubes out.... but nothing is NEEDED to be done.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #4 of 5 Old 02-15-2013, 09:51 AM
Zakman
A locked & armored LJ
Zakman's Avatar
Just a thought here.
I would check your axle shaft u-joints and ball joints while everyting is apart.
Easier to fix / replace now then when you get everything back together.
edit: Check wheel bearings and brake pads / rotors while you're at it.
My Build Threads:
2005 LJ - "Squad 51"
2002 TJ - "Minion" - RIP - 06/02/16 @ JJUSA - Badlands
Zakman is offline
post #5 of 5 Old 02-15-2013, 09:58 AM
jeepn012
Might be a good idea to check the condition of the rubber hose that connects to the diaphragm on the locker. That is if you're still running the stock setup....Not required, but you asked!!
1990 YJ - 96 to 03 My first. She will be missed.
2004 TJ - 03 to 11. Old Faithful. I will have another TJ one day.
2007 JKU - SOLD
2005 LJ - In the mail, hope I like it. Everybody's doin it, here is the build:
jeepn012 is offline
axle , dana 44 , differential , rubicon , seal
