Rubi D44 for $1400 - JeepForum.com
post #1 of 55 Old 02-09-2008, 07:25 AM Thread Starter
jays-tj
When is it enough?
jays-tj's Avatar
Rubi D44 for $1400
I was just looking through my Peterson 4 wheel and off road magazine and it has an article on the JK Rubi D44 Axle for $1,400. E-locker, 4.10 gears, disc brakes and the front one is high pinion. That sounds like a screaming deal!! It's not a direct bolt in swap to a tj, but the article makes it sound like the swap isn't too bad. Has anyone heard of this or done this swap? I'm not looking into it for me, but a buddy is looking at upgrading. Any thoughts?
5.5" RELA
NorCal Crawlers W6JLO
jays-tj is offline
post #2 of 55 Old 02-09-2008, 08:42 AM
TJW909
I read the same info let's hear some info if anyone has done this. I'am getting ready to do an axle swap rebuild of some sort with the 35 thread going and then seeing this I'am trying to make my mind up and get rolling.
TJW909 is offline
post #3 of 55 Old 02-09-2008, 08:49 AM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
The bolt pattern is different for the rim. 5x5.5 I think.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #4 of 55 Old 02-09-2008, 08:51 AM
TJW909
I didn't like that part but you are right the pattern is different
TJW909 is offline
post #5 of 55 Old 02-09-2008, 09:00 AM
CCrew
And the axle is 5" wider. If you search it's been pretty much beaten to death here and I haven't seen anyone sucessfully do an install.
-R
CCrew is offline
post #6 of 55 Old 02-09-2008, 09:02 AM
TJW909
-R
OUCH. I did not check on the length thats a lot. Thaks for the info
TJW909 is offline
post #7 of 55 Old 02-09-2008, 10:29 AM
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
Could you not get some spacers for the frontend and also get the 5 on 5 lug pattern? Problem solved if that a viable options.
1948 CJ2a
Airborne4X4 is offline
post #8 of 55 Old 02-09-2008, 10:40 AM
fromme
fromme's Avatar
I think you misunderstood...the JK axle is 5" wider. That in itself is a big problem. Spacers will make it even worse, so you have to buy new wheels with a lot of backspacing, and it still wouldn't be desirable. I'm sure it can be done, but you'd have to do both axles.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #9 of 55 Old 02-09-2008, 12:25 PM
newbs
Jeepaholic
JK axle is wider and that would not be a problem, IE wheels with less backspacing. JK axle is actually 5x5 not 5x5.5 like old cj's either use adapters which you can already buy or just buy new wheels, brackettry is where your main problems are. The JK 44's also are stronger than TJ 44's thicker tubes higher spline count and maybe more.
newbs is offline
post #10 of 55 Old 02-09-2008, 12:44 PM
fromme
fromme's Avatar
Wheels with less backspacing will make them stick out even farther. You'd need wheels with more backspacing to tuck them under. Unless you find/use a wheel with a 6" +/- backspace, it's going to be a pretty wide track. Which may not be a problem, but you'd have to be willing to accept that.
fromme is offline
post #11 of 55 Old 02-09-2008, 12:48 PM
badassr1
1995 XJ Cherokee
haha I did this swap front and rear... I did it under my xj though. Front all you have to do is move the spring perches in 1 3/4's... Rear is simple as well... Just a little cutting and welding. And yes your right its tube is much thicker and axle shaft are much larger. And the witch is alwsome. Wider is a good thing, keeps you right side up. Best money spent for sure.
badassr1 is offline
post #12 of 55 Old 02-09-2008, 01:13 PM
CCrew
Simple for your XJ rear. Brackets for your leaf springs and you're pretty much done. By the time you buy a bracket kit, move all the brackets/convert to TJ setup you're probably in the ballpark of a turnkey 44 already set up for a TJ. Nothing really gained after you have to replace the wheels (more$ ) to deal with the bolt pattern.
Front I could make an argument for considering it's a HP axle, but the TJ knuckles won't fit that either. Any way you go it's *much* more than $1400 an end to do the swap.
-R
CCrew is offline
post #13 of 55 Old 02-09-2008, 02:53 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
...Front I could make an argument for considering it's a HP axle, but the TJ knuckles won't fit that either. Any way you go it's *much* more than $1400 an end to do the swap.
-R
The JK front axles are complete with brakes and everything, so the TJ knuckles being different is no big deal.
Wheelin98TJ is offline
post #14 of 55 Old 02-09-2008, 02:58 PM
Greg_Volkman
some guy on the JU TJ forum is doing it right now.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline
post #15 of 55 Old 02-09-2008, 05:04 PM Thread Starter
jays-tj
When is it enough?
jays-tj's Avatar
-R
the Jk front is a high pinion. I haven't done the JK swap or read about the JK swap but a D44 ready to bolt in to a tj is around $2500 +/-. hard for me to belive that a shop couldn't cut and or weld the correct brackets on a jk D44 for less than $1,100.
5.5" RELA
jays-tj is offline
Rubi shocks when changing to rubi springs? DocJake JK Wrangler Technical Forum 1 10-13-2009 08:36 PM
Rubi D44 thick gear in a non Rubi D44? mobyjeep TJ Wrangler Technical Forum 11 07-05-2009 05:00 PM
Rear Rubi locker in front Rubi axle. NotURMailman TJ Wrangler Technical Forum 4 05-08-2009 10:56 PM
1400. dollar YJ moonshinefuel YJ Wrangler Technical Forum 2 05-06-2009 08:20 PM
Am I wrong for buying this car?Paid $1400.00 fooswinger YJ Wrangler Technical Forum 17 07-18-2007 03:48 PM
