Rubi Air Locker issue! HELP!! - JeepForum.com
post #1 of 16 Old 02-20-2011, 09:55 PM Thread Starter
BSaint
Hey guys,
I have a cut line in my stock rubi air locker, so as you can probably imagine the locker no longer engages. Does anyone know the name of this part of where I can order a replacement from? Also, it seems like a pretty easy fix...but looks can be deceiving. Has anyone ever had this issue before? thanks!
~Brad
BSaint is offline
post #2 of 16 Old 02-20-2011, 09:56 PM Thread Starter
BSaint
if you cannot tell from the picture, one end of the line section goes into the housing, and the other half connects to the plastic adapter thing. I hope this helps. thanks guys!
BSaint is offline
post #3 of 16 Old 02-20-2011, 10:19 PM
LiveT
looks like the sensor wire to tell the dash light that the locker is infact engaged.
http://www.jeepsareus.com/p/WDAir.html
Im not 100% if this is the part you need or not but it says it goes from the air locker to the pumps.
Jeeps dont break, they make opportunities for improvements
LiveT is offline
post #4 of 16 Old 02-21-2011, 01:45 AM
bojang
You will need to pull your diff to replace that switch. Your locker does probably in fact engage, your light should just keep flashing.
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline
post #5 of 16 Old 02-21-2011, 07:58 AM Thread Starter
BSaint
do you know where i can get this part? or about what it will cost? i opened the diff last night and everything looked good. But ill open it again and see if i can tell how it connects on the inside. thanks
~Brad
BSaint is offline
post #6 of 16 Old 02-21-2011, 09:21 AM
beartree
I had to replace the one on my front axle after my wires broke off. Your locker will still work, but the light will not come on in your dash. I went to the parts department at my Jeep dealer and ordered a new switch. The 2003 factory service manual does not say what to torque the switch when installing. Be careful not to over tighten since this will force the air locker to stay locked all the time.
beartree is offline
post #7 of 16 Old 02-21-2011, 09:25 AM
Sundowner
Try junkyarding it first...you might be able to source it for next-to-nothing. I've found a few scrapped Rubi's that college kids rolled or otherwise trashed. Weird little parts like that are usually still there.
Sundowner is offline
post #8 of 16 Old 02-21-2011, 09:29 AM
beartree
Oh, Jeep calls it a locker indicator switch.
beartree is offline
post #9 of 16 Old 02-21-2011, 10:33 AM
danielbuck
1946 CJ2
this is what mine does. My front locker-light never stops blinking, but it does in fact lock and unlock as it should.
danielbuck is offline
post #10 of 16 Old 02-21-2011, 01:06 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
How would over tightening the indicator switch cause the locker to stay engaged?...
Knuckelhead is offline
post #11 of 16 Old 02-21-2011, 01:10 PM
danielbuck
1946 CJ2
is it referring to the oil drain plug maybe? I have heard that if this is tightened to much it will interfere with the locker.
post #12 of 16 Old 02-21-2011, 03:30 PM Thread Starter
BSaint
now lets say these rubi axles were going to be installed on a non-wrangler model. would this cut indicator wire even be an issue, or would it be almost irrelevant based on the fact that the non-rubicon model does not have locker lights anyways? Do people normally install the locker lights on their jeeps when they axle swap, or do they run it without the indicator lights? I have a feeling most would run it without the indicator lights, but let me know. thanks
~Brad
BSaint is offline
post #13 of 16 Old 02-21-2011, 03:36 PM Thread Starter
BSaint
also, can anyone confirm that this is the part I would need to replace the locker indicator wire?
thanks
~Brad
BSaint is offline
post #14 of 16 Old 02-21-2011, 06:10 PM Thread Starter
BSaint
Do you recall approximately what the part cost you, and how labor intensive the job was? Was it an easy fix or did it require removing the internals? thanks!
~Brad
BSaint is offline
post #15 of 16 Old 02-22-2011, 01:15 AM
bojang
thanks
~Brad
No, that is your pump wiring and air lines.
http://www.4wheelers.com/jeep-rubico...91-p-3725.html
~Brad
You need to pull the diff to replace the switch........
Chris
bojang is offline
Stock Rubi Air Locker Issue. Help BSaint TJ Wrangler Technical Forum 5 10-17-2010 08:07 AM
will this locker fit my rubi d44? mudb8 TJ Wrangler Technical Forum 1 12-12-2009 08:38 PM
Rear Rubi locker in front Rubi axle. NotURMailman TJ Wrangler Technical Forum 4 05-08-2009 10:56 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
LOCKER ISSUE > Just installed lunchbox locker - problems msavard TJ Wrangler Technical Forum 7 12-26-2006 11:11 PM
