Rubbing sound from my wheel wells - JeepForum.com
post #1 of 6 Old 03-05-2011, 07:17 PM Thread Starter
TRBO17
Hey there. Whenever i turn my wheels all the way to the right or left, there is a loud rumbling sound and it shakes my jeep. I have a 2000 TJ with a 2" lift and 31" BFG A/T. Are my tires just hitting my coils or is it an issue with my backspacing etc...?? Thanks for the help. Also, I want to get Cragar soft 8's (15x8) would this help or hurt the situation? Thanks again
TRBO17 is offline
post #2 of 6 Old 03-05-2011, 07:28 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Sounds like a backspacing issue. Tires are hitting when turned to full lock.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 6 Old 03-05-2011, 08:15 PM
BomberJeep
2011 WK
You can adjust your turn stops with,washers if I'm not mistaken.
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
post #4 of 6 Old 03-05-2011, 08:38 PM
ForumKing
I would check your sway bar links as well. The ball joints get old after a while and pop out causing a rubbing sound when turning the wheel all the way.
ForumKing is offline
post #5 of 6 Old 03-05-2011, 09:32 PM
lancetkenyon
Tires can also rub on the sway bar itself. Or LCAs. Look for shiny spots on the sway bar and LCAs. Might be touching a bolt head on the inner fenderwells too.
Flexes like a boneless hooker on muscle relaxers.
lancetkenyon is offline
post #6 of 6 Old 03-07-2011, 11:47 PM Thread Starter
TRBO17
thanks guys. it looks like theyre hitting the sway bars even though theres no significant marks, it may just not have happened enough to mark the bars up
TRBO17 is offline
coils , tires , tires rubbing , wheel back spacing
clutch noise-clutch plates rubbing? Sound like rubbing your palms together anderson1791 TJ Wrangler Technical Forum 14 11-30-2009 01:44 PM
Changing from a 4" springs and rubbing wheel wells to a 6" springs (Will it help?) jdridin YJ Wrangler Technical Forum 9 06-19-2009 09:36 AM
Wheel wells... Rocky529 TJ Wrangler Technical Forum 8 11-26-2004 10:12 AM
how 2 remove inner wheel wells SLINKY-YJ YJ Wrangler Technical Forum 1 03-10-2004 01:14 PM
wheel wells? jeeptoplesstx TJ Wrangler Technical Forum 6 01-19-2004 06:25 PM
