Rubbing with 3 inch Lift, possible solutions? - Page 2 - JeepForum.com
post #16 of 21 Old 06-02-2012, 01:52 PM Thread Starter
Krytos
One washer was all it took, no more rubbing.
Thanks for all the help.
Miami Jeeper lamenting the loss of my Air Conditioning
Krytos is offline
post #17 of 21 Old 06-23-2012, 03:19 AM Thread Starter
Krytos
make sure you do your homework on the clearance issues. you will need appropriate bumpstop extensions or you'll be bashing your track bar into the diff cover or tie-rod.
Ok, so I read through the 80 Page adjustable track bar thread and have some questions and a tentative plan.
Like I mentioned before, I have a 3inch Zone lift with a front Dana 30 with the stock diff cover, no armor or anything. The stock track bar is moved over in a newly drilled hole.
My plan is to run a CE-9120TJJ in the original hole (with the second, newer hole welded over).
Will I still have to run 2 inches of bump stop with the above proposed setup?
Krytos is offline
post #18 of 21 Old 06-23-2012, 06:44 AM
rda616
Yes is the short answer. If you have already moved the mounting point and recentered the axle you don't really need an adjustable unless you are binding the stock track bar.
rda616 is offline
post #19 of 21 Old 06-23-2012, 06:47 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
That is a good plan
Here's a write-up on reinforcing the bracket: http://www.jeepforum.com/forum/f9/br...racket-905624/
Yes, using the stock diff cover or a Barnett/T&J cover. Other covers will be worse.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #20 of 21 Old 06-23-2012, 12:20 PM Thread Starter
Krytos
Follow up, If I keep the stock track bar on the new location with a reinforced hole, I still run the 2 inch bump stop extensions, right?
Krytos is offline
post #21 of 21 Old 06-23-2012, 12:36 PM
rda616
You need to follow the link in unlimited04's sig on how to properly set your bump stop extensions. There is no way of knowing what the minimum size you can use will be without test fitting per the writeup in the link.
rda616 is offline
33s , adjustable track bar , rubbing , track bar , zone 3" lift
Two inch body lift= 2 Inch motor mount lift? TOLjeep TJ Wrangler Technical Forum 12 10-01-2011 09:36 AM
2 inch spacer lift vs 4 inch suspension lift and Death Wobble BadKarma1701 TJ Wrangler Technical Forum 37 03-10-2011 07:00 PM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
Rear track bar rubbing on springs, solutions? Warlord2 JK Wrangler Technical Forum 3 04-19-2009 01:10 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
