Quantcast RTV Bead or Smear? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > RTV Bead or Smear?
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
View Poll Results: On a diff. cover, do you leave the RTV in a bead, or smear it around?
Leave it in a bead 65 85.53%
Spread it around, like butter on toast. 11 14.47%
Voters: 76. You may not vote on this poll
Old 01-03-2007, 10:01 PM   #1
robert92679
RTV Bead or Smear?
Just wondering, when you install differential covers, do you leave the RTV in a solid bead, or smear it around?
Do you think there are any benefits to one method or the other? Or, does it really not matter?
2005 Unlimited Rubicon See it here...
robert92679 is offline   Reply With Quote
Old 01-03-2007, 10:10 PM   #2
paultyler
Uncle Paul has spoken...
paultyler's Avatar
You are suppossed to put down a bead. When you put the cover on it will spread out. If you smear you may get a leak.
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote
Old 01-03-2007, 10:14 PM   #3
RockRunner85
I run about a 1/4 inch bead all the way around the cover. I go around each bolt hole, even though you really only need to go around on the inside the bolt hole.
Make sure you read the directions. Most have an hour wait time. If you do not follow the directions it will leak!!!
Most say after running the bead bolt cover in place finger tight. Let sit an hour. Then torque down bolts and fill.
The one time I was in a hurry I just tightened the bolts and filled the diff. It starting leaking 5k later.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
The Reptile File
A discussion forum on geckos, lizards, snakes, and other reptiles.
RockRunner85 is offline   Reply With Quote
Old 01-03-2007, 10:19 PM   #4
BlueFlame
It takes RTV a heck of a lot longer than an hour to set.
Agree on just snug it down and then wait, but I usually wait overnight to torque then fill.
On the other hand, I've never seen a shop wait, and they seem to seal fine...
BlueFlame is offline   Reply With Quote
Old 01-03-2007, 10:24 PM   #5
kizer
I place a bead and then smear it around to insure the entire surface has a thin coat. I torque all the bolts just a little bit less than spec then again at spec. Ive yet to wait any longer than 10minutes and Ive never had a leak.
Its never failed and since it works for me Im going to continue my method. Is it the correct method? Sounds like it isn't, but it speaks for it self.
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
kizer is offline   Reply With Quote
Old 01-03-2007, 10:32 PM   #6
Rocky529
Jeep
Rocky529's Avatar
Leave it in a bead, and avoid placing the bead around your holes in the cover. Gently place the cover against the differential, and hand thread all the bolts. Once you crank them down, the RTV should not smear onto the threads of the bolts and a little RTV should "ooze" out creating a seal.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 01-03-2007, 11:01 PM   #7
Michael_K
Bead, otherwise you are risking bubbles.
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline   Reply With Quote
Old 01-03-2007, 11:21 PM   #8
alvinl
I have always used a bead and run it around all bolt holes. I do 1 diff, snug the bolts up finger tight then let it dry while I do the other diff. Or let them both sit while changing the tranny and transfer case fluid. Then torque down and fill. So I give them some time to dry, but not overly long. I have yet to have one leak. But now that i've said that, I bet my last diff job leaks...
alvinl is offline   Reply With Quote
Old 01-04-2007, 01:56 AM   #9
Materdaddy
Bead, Bead, Bead!!!
1997 TJ
O|||||||O
My
MyJeep
MyJeepRocks
Materdaddy is offline   Reply With Quote
Old 01-04-2007, 02:22 AM   #10
UCTJ
Put a nice even bead...not too thick it will just spooge out anyway. But a nice even bead, never had a diff on me.
UCTJ is offline   Reply With Quote
Old 01-04-2007, 03:06 AM   #11
Brew461
Is it a concern if the RTV "spooges" a little to the inside and makes it into the carrier?
Brew461 is offline   Reply With Quote
Old 01-04-2007, 04:21 AM   #12
Jeremy99
I have reusable gaskets now, but in the past I would apply a bead and spread it evenly across the sealing surface. I would then wait 3-5 mins for the sealant to "film" over (allow the exposed layer to begin to set), then I would install the cover and finger tighten the bolts. I have never allowed time before I torque down the bolts, not that it was a race to tighten them or anything. I never had any leaks. Seems like I read that method on the back of a tube of sealant one time.
Jeremy99 is offline   Reply With Quote
Old 01-04-2007, 06:23 AM   #13
Michael_K
Unless you got something sensitive like limited slip clutch, I would not worry about RTV damaging high strength steel.
Michael K.
DailyDrivenTJ.com
Old 01-04-2007, 08:16 AM   #14
PeteC
Bead.......always a bead.
Let the pressure of tightening the metal surfaces together spread the material. That is the way this stuff was designed to work. The pressures will put it where it needs to go. If you smear it on in a thin coat you may not have enough in a certain spot to fill all voids. Even cork gaskets had some give to fill voids. Actually, I was raised to use a thin bead of RTV on cork gaskets just to insure a first time seal. Overkill maybe, but hell, my dad learned that as an aircraft mechanic.
Anyway, that's how I roll.
p.s. For those that use the smear method, if it works for you, cool.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline   Reply With Quote
Old 01-04-2007, 10:40 AM   #15
BlueFlame
I think the answer to getting a leak free seal is Clean Surfaces.
I don't think beading, smearing, paper gaskets or rubber gaskets matters so much, but good clean surfaces for the sealing medium to seal to is important - even more so with silicone than with gaskets.
Glock Forum
