RT Turn Signal/Brake light - JeepForum.com
post #1 of 3 Old 03-30-2007, 11:23 AM Thread Starter
tjtone
I have read all the threads for Flasher/blinker and brake light problems, I left my top off the other night and it rained in my 1999 TJ. Had the clicker problem, Sprayed with WD40 let it dry no more clicking noise. Now when I hit the brake the rt clearance lights come on, and the right turn signal stops blinking. Checked all bulbs and checked all grounds...all seem fine. Can anyone help me with this?
tjtone is offline
post #2 of 3 Old 03-30-2007, 11:29 AM
mpyusko
did you check for corroded contacts on the relay it's self.
I have a funny problem because of the relay's location:
Left TS and Right TS work fine. When I hit the 4-ways, only the left TS comes on and it blinks really really fast! So then I have to flip the right TS on at the same time, now my 4-ways flash fine.
I replaced the front soft windows in my jeep and I kept the old ones to cut the plastic up and make a shield for the flasher relay.
-mpyusko
_________
'97 SE Black, 4cyl/5spd, Soft top, Jeeperman Rear Bumper, 33x12.5x15 Trxus M/T's, 4" Lift, 1" JKS MML
BLACK JEEP Club V2.0 #84
Rust-Bucket Build-Ups Club Member
mpyusko is offline
post #3 of 3 Old 03-30-2007, 12:27 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
as stated above check relay, then maybe some rtv around it to keep water out
RnEmOvr is offline
turn signal/brake light problems m1kemcc TJ Wrangler Technical Forum 3 06-20-2009 07:51 PM
right turn signal and brake light not working DMC0627 TJ Wrangler Technical Forum 4 05-20-2009 04:23 PM
Separating turn signal from brake light? TJmudpuppy TJ Wrangler Technical Forum 11 12-11-2008 01:41 PM
Turn signal/brake light problem Help! ksm279 TJ Wrangler Technical Forum 3 04-07-2008 11:24 AM
Turn Signal and Brake Light Jeep_Grrl TJ Wrangler Technical Forum 8 08-13-2005 03:24 PM
