RPMs Increasing - JeepForum.com
post #1 of 8 Old 07-21-2010, 07:31 PM Thread Starter
dschild
RPMs Increasing
2003 Wrangler Sport 4.0
55,000 miles
All of the sudden my RPMs started bouncing up. Today was the worst. My usual idle is a line under the 1,000 RPM mark. Lately it's been going up to 1,000 and a line over 1,000 (1,250?). Earlier today I started the engine and the RPM hovered at 2,000. I turned off the engine, restarted and it rested back at 1,000 - 1,250..
AC is off.
I recently changed oil and wonder if this is the reason. I used 5W30 Synthetic. I live in Seattle. It's about 70 degrees +/- right now.
Ideas?
dschild is offline
post #2 of 8 Old 07-21-2010, 07:43 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Try checking your vacuum lines.After that... when have you last cleaned your throttle body?Oil would hyave nothing to do with engine rpm!
GOLENJEEPTJ is offline
post #3 of 8 Old 07-21-2010, 07:50 PM Thread Starter
dschild
I looked at the vacuum lines. I replaced the emmissions hose since it was visibly damaged. The other hoses all look fine as far as I can tell eye-balling..
Do I risk anything using that weight of oil, or should I consider changing it out too?
dschild is offline
post #4 of 8 Old 07-21-2010, 07:51 PM
04_Sahara_Man
What about when I press my clutch in sometime and let off the gas the revs jump up a bit?? happened a couple of times
Currently 04 Sahara: 3" BDS lift, 9500 BDS Monotubes, Flowmaster Super 44, Olympic Rocker Guards, 33" Duratracs, 15x8 Black Rock Blades.
Khaki Jeep Club Member
In Pennsylvania, fun is illegal
Xbox live GT - TheExecutive00
Tama, Paiste, DW, Zildjian, Vic Firth....yes I go boom boom!
04_Sahara_Man is offline
post #5 of 8 Old 07-21-2010, 08:10 PM Thread Starter
dschild
Mine isn't doing that. It stays at level consistently. I just went outside to see what else I might find. RPMs were down under 1,000 where I would consider normal based on my experience with this jeep. I couldn't get it to repeat this time. I checked all the hose connections. Looked at the ends to check for cracks etc.. Nothing stood out. Truly wishing I knew more about engines right now.
Only things I've done to this jeep is changed plugs, did a quick seafoam application to fuel and brake vacuum hose, and changed oil. I did check to make sure the brake vacuum hose is seated right. This problem started several weeks after that activity anyway.
dschild is offline
post #6 of 8 Old 07-21-2010, 08:30 PM
Jon-joN
sounds like a vacum leak of somekind. my jeep will idle unde 1000 when sitting but if im slowing down it stays about 1200. wich i dont mind cuhs it helps the brake booster a little more.
Jon-joN is offline
post #7 of 8 Old 03-26-2011, 10:36 PM Thread Starter
dschild
New AIC motor fixed it
David Schild
KK6CQX
/73
dschild is offline
post #8 of 8 Old 03-27-2011, 12:17 AM
jhf56
a lot of times it is the IAC that needs to be cleaned i think
Rubicon, BDS, BFG, atoz, Rokmen, Riddler, Body Armor, UCF, etc
My Rubicon Build
http://www.jeepforum.com/forum/f9/2003-rubicon-build-1152937/
jhf56 is offline
rpm increase , rough idle , help , advice , tj , wrangler
Increasing Lift Height - Help Drew43 TJ Wrangler Technical Forum 3 11-28-2006 11:58 PM
Increasing caster? vadslram YJ Wrangler Technical Forum 1 10-23-2006 07:16 AM
Increasing Torque jeepramnauth TJ Wrangler Technical Forum 1 10-03-2004 01:32 PM
Increasing Vibration EricS TJ Wrangler Technical Forum 13 06-17-2003 08:40 PM
Increasing the Idle jess YJ Wrangler Technical Forum 2 07-02-2002 11:06 PM
