Quantcast RPM's at Final gear Ratio with 5speed and 6Speed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > RPM's at Final gear Ratio with 5speed and 6Speed
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 09-18-2005, 06:48 PM   #1
Scoobert
I seen several post with people asking what RPM they would have with certain tires and rear axles. Since all the links we give out our normally for a 1:1 Ratio (ie a 5 speed in 4'th or a 6 speed in 5'th) I thought it would be handy to to make up a couple spread sheets with both tranny's listed at final ratio (ie .78 on the 5sp and .84 on the 6sp).
I hope this can help some people
*NOTE* Both transmissions in highest gear and at 65 MPH
*Information and Ideas gather from http://www.4lo.com/ a nice site with lots of calculators *
Scoobert is offline   Reply With Quote
Old 09-18-2005, 09:37 PM   #2
orangetj05
not to be rude but your chart isn't very acurtate for the 6 speed with 31 my runs about 2500 at 65.
2005 TJ Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
ORANGE JEEP MEMBER #8
orangetj05 is online now   Reply With Quote
Old 09-18-2005, 09:56 PM   #3
Dogman
I think it's something like:
mph = Miles Per Hour
x = Overdrive Ratio
y = Gear Ratio
z = Tire Diameter
((mph * y * 336) / z) * x = RPMs
Dogman is offline   Reply With Quote
Old 09-18-2005, 10:06 PM   #4
Scoobert
Is that with your speedo having the correct gear in it to compensate for the 31's?
by this fomula
you should have
? X 31
------------------= 65
3.73X.84X1X336
Which would be the same (I think, any math majors here?) as saying
3.73 X .84 X 1 X 336 X 65 (68429.08) / 31 = 2207 RPM
Old 09-19-2005, 08:54 AM   #5
35sUnlimited
The chart may assume a 31 inch tires is actually 31", when in reality it is probably more like 30". Every tire brand varies slightly. Even the same brand will vary depending on the size rim it is on.
I think the charts are pretty/cool useful. Just have to measure your own tire to see actual diameter.
This link to a calculator on Randy's site is cool beacause you can put in exact numbers. http://www.ringpinion.com/content/calculators/RPM.asp
Use the second one down.
35sUnlimited is offline   Reply With Quote
Old 09-19-2005, 02:38 PM   #6
k8ysv
For a 31 inch tire and 4.56 gears (which is what I looked at because that's what I'm running)...
How is it that @65 MPH in top gear for a 5-speed, the listed RPM is 2506, but in top gear on the 6-speed it's HIGHER (2699 RPM)? This doesn't make much sense.
Or is it just me?
2004 Patriot Blue Wrangler X, 33"x10.5" BFG Mud Terrains, 4WDH 2" lift with 3/4 inch spacers, 1" BL, 1" Brown Dog MML, Yukon 4.56 gears, Yukon Super 35, ARBs front and rear, Warn 9.5ti winch, GPS, MP3, Some hooks and lotsa skids.
k8ysv is offline   Reply With Quote
Old 09-19-2005, 03:10 PM   #7
Scoobert
Or is it just me?
Nope its not you. The 6 Speed actually has a lower ratio @ .84 (higher #) in high gear then the 5 speed which is a .78.
Old 12-03-2005, 09:48 AM   #8
airduds
here's a good calculator
http://intercotire.com/site58.php
2000 Sport 4.0/both tops/5sp/4.88s/Dana 44 Truetrac rear/Dana 30 Aussie Locker front/Ramsey 9500 receiver mounted for front and rear/RE 5.5" LA/15"x10" M/T Classic II's/Dunlop Mud Rover 35's/TBT Alumi-Flex tie rod
airduds is offline   Reply With Quote
Old 12-03-2005, 10:23 AM   #9
coorsmgood
2010 JK Wrangler
so where do you find your tc and tranny ratios?
2010 4 door wrangler stock for now in burnt orange longhorns style!!
coorsmgood is offline   Reply With Quote
Old 12-03-2005, 10:25 AM   #10
coorsmgood
2010 JK Wrangler
I like your idea of making ONE good chart scoob...let me know when you get this all worked out!
Old 12-03-2005, 10:28 AM   #11
JeepJohnson
NSG370(6 speed) 1:4.46, 2:2.61, 3:1.72, 4:1.25, 5:1, 6:0.84, R:4.06
NP231 HR:1, LR:2.72
NP242 HR:1, LR:4
JeepJohnson is offline   Reply With Quote
Old 12-04-2005, 02:51 AM   #12
iismet
My Junk
2005 SE 2.4L
4.56 Gears
Corrected Speedo Gear
32" Mud Rovers @ 25 psi
6th gear:
2600 rpm =>60 mph
2800 rpm =>65 mph
3000 rpm =>70 mph
iismet is offline   Reply With Quote
Old 12-04-2005, 06:45 AM   #13
JeepJohnson
Better recheck to make sure you have the right speedo gear, with 4.56s and 32s you should be turning 2600 at 65.
Old 12-04-2005, 06:49 AM   #14
hvac59
2100 rpm's @65 (per GPS) with 3.73's/33 BFG MT @22 psi
hvac59
White 01 WJ (stock 4.7 limited)
White 08 MK Patriot (minor mods) -SOLD-
Looking for a White (ultralite?) project Jeep -FOUND-
White 09 JK "X"
hvac59 is offline   Reply With Quote
Old 12-04-2005, 07:01 AM   #15
JeepJohnson
hvac59
When your speedo is off I'm assuming it throws your tach off too right? I just went from the stock 27s to 29" MT/Rs and my tach is reading the same RPMs as it was before. BTW, 2100 is right on the money, so my math ain't off.
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
