RPM Revving issue - JeepForum.com
post #1 of 5 Old 06-24-2010, 08:49 PM Thread Starter
davekippen
RPM Revving issue
My 99 Wrangler 4.0 started having RPM issues about a month ago. Sporadically the RMP's jump way up for a while then go back down to normal idle RPM. It happens when sitting at a light in drive and also if it is in park, just idling. It often revs way up when i put it in park after stopping. Thoughts?
davekippen is offline
post #2 of 5 Old 06-26-2010, 06:16 PM Thread Starter
davekippen
Anyone?
post #3 of 5 Old 06-26-2010, 06:20 PM
1fastR
1fastR's Avatar
How old is your battery? I had a somewhat similar issue once and my battery was going bad. It could be a vacuum leak as well. Have you replaced the exhaust manifold or anything lately?
1fastR is offline
post #4 of 5 Old 06-26-2010, 06:23 PM
HerkEng
1971 J-Series Truck
When did you last clean your throttle body and IAC?
HerkEng is offline
post #5 of 5 Old 06-26-2010, 06:24 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A vacuum leak is often responsible for high rpms, has anyone worked on or around the intake manifold lately?
Jerry Bransford is offline
high rpm , vacuum , leak
Engine revving up when braking? chefdab TJ Wrangler Technical Forum 22 11-29-2011 04:37 PM
Revving out when Started jeff83 TJ Wrangler Technical Forum 3 05-09-2009 11:43 AM
4.0 stalling after revving choeyreplied TJ Wrangler Technical Forum 1 11-06-2008 11:57 AM
revving at start up?? attackcammel TJ Wrangler Technical Forum 2 09-11-2008 10:22 AM
Jeep Revving to high cspoffroad TJ Wrangler Technical Forum 3 01-04-2005 04:47 PM
