Quantcast Routing air intake up under the vent panel? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Routing air intake up under the vent panel?
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 07-01-2008, 02:25 AM   #1
TheMightyGoat
Excuse my faulty memory; I've forgotten the proper name for that panel. I'm referring to the one behind the hood, through which the wipers are mounted.
I'm thinking of routing my air intake through the engine bay and under that panel as a sort of quasi-snorkel. I'm not going to be taking my Jeep through any serious mud/water as it's my daily driver and I don't need to worry about changing all my fluids that often, but I do go through mudholes occasionally and I'm thinking moving the intake up there would offer some added protection against sucking up water without giving my Jeep that ******baggerous look of a homemade intake drilled into the hood. Plus, the air up under that panel should be a fair amount cooler than the air in the engine bay.
Thoughts?
TheMightyGoat is offline   Reply With Quote
Old 07-01-2008, 02:51 AM   #2
RnEmOvr
Never Forget
RnEmOvr's Avatar
cowl, look here
http://www.jeepforum.com/forum/f9/started-another-project-vehicle-423989/index30.html
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 07-01-2008, 02:55 AM   #3
Hapytruck01
Here is mine http://www.jeepforum.com/forum/f9/cowl-intake-windstar-air-box-566973/
Hapytruck01 is offline   Reply With Quote
Old 07-01-2008, 03:04 AM   #4
TheMightyGoat
Originally Posted by rnemovr View Post
Oh.
I just skimmed over most of your thread and apparently missed that piece of information.
Old 07-01-2008, 09:08 AM   #5
TJ Rat
What about some sort of shaker hood similar to what was an option on Mustangs/MoPars/Firebirds? I have not seen anybody try this.
USMC - When America needs 911.
Growing Old is Mandatory, Growing Up is Optional.
Mud is a Requirement Either Way!
TJ Rat is offline   Reply With Quote
Old 07-01-2008, 09:17 AM   #6
vincec
I ran mine through the cowl using the original air box and some fittings from lowes I don't have a pic but if you want I can explain in detail for you cost like 30 bucks
vincec is offline   Reply With Quote
Old 07-02-2008, 01:49 AM   #7
PyroXian
"cowl vent snorkel" or "cowl induction" is the phrase you want to search for. Many write-ups.
I wish I had enough money to drive stupid.
Don't click this:
ʇǝu˙ʞɔɐɹɔ˙ʍʍʍ
PyroXian is offline   Reply With Quote
Old 07-02-2008, 09:32 AM   #8
Bigbob
Bigbob's Avatar
I'm thinking of routing my air intake through the engine bay and under that panel as a sort of quasi-snorkel. Plus, the air up under that panel should be a fair amount cooler than the air in the engine bay.
Thoughts?
It will work very well. Just have to find a filter that fits. You can also put a scoop on the vent to keep rain out a bit. For added fuel mileage re-locate the IAT sensor to the intake tube, I think yours is mounted in the manifold. I have this on mine and besides getting the air intake up a couple inches, it also has much more power and 2-3 MPG better mileage.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 07-03-2008, 10:28 AM   #9
vincec
What is an IAT sensor and where is it located?
Old 07-03-2008, 10:44 AM   #10
adam728
What I don't like about that one is the fact that you need to pull the cowl to clean or even just check the air filter.
Sienna Jeep Club - Member #8
Plans and pics, put an 8" sub in your TJ center console
adam728 is offline   Reply With Quote
Old 07-03-2008, 11:03 AM   #11
Bigbob
Bigbob's Avatar
Pre '05 or '06 models have them threaded into the manifold. Sort of looks like a temp sender unit. The '06 models have them in the air tube, maybe '05 as well.
INTAKE AIR TEMP is what it stands for. The units mounted in the manifold give false readings as they become a heat sink. Mount them in the tube and insulate the tube and there is a much truer reading.
I think 2-3 mpg better mileage makes the hassle worthwhile. And being mine has 2 filters the inside filter should not get dirty that quick. The top filter which collects the majority of dirt is easy to get to.
I am doing a long trip today and will report back with mileage. I expect about 17 mpg or so.
6 Speed, Hardtop
Old 07-03-2008, 11:08 AM   #12
adam728
I didn't mean it won't work. I just prefer the setups with an airbox under the hood, then some piping from that into the cowl.
I'm one of those weirdo's that checks his filter pretty much any time I open the hood.
Old 07-03-2008, 01:41 PM   #13
TJ Rat
Repost.....
Old 07-03-2008, 01:46 PM   #14
TJ Rat
I'm with ya on that one. Make a routine maintenance item difficult to get to it will no longer be a routine maintenance item.
Old 07-03-2008, 05:30 PM   #15
Bigbob
Bigbob's Avatar
One of the ideas, besides the couple extra inches in height, of mounting the air box/filter in the cowl is to get it away from all that under hood heat. Hence, cold air induction- - CAI. The air box under the hood is an oven/heat sink. Having the air come from the cowl does indeed help, but just having a insulated tube is better.
6 Speed, Hardtop
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
