rough on startup - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > rough on startup
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 08-07-2005, 07:18 PM   #1
seachange
rough on startup
i have a 2001 tj sahara, when i start it up in the morning its a little rough for the first 30 seconds or so, is this normal or something i should look into?
seachange is offline   Reply With Quote
Unread 08-07-2005, 09:11 PM   #2
StealthTJ
<SNIP>
No...
Fred
[b]Base[/b] - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
[b]Suspension[/b]- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
[b]Misc[/b] - Tera 2wd lo.
[b]Tires[/b] - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
[b]Recovery[/b] - Warn XD9000i
StealthTJ is offline   Reply With Quote
