Rough Idle when cold - JeepForum.com
post #1 of 2 Old 07-28-2008, 03:39 PM Thread Starter
firefighter1
I have a 98 TJ, 4.0/Auto. Jeep would crank but not start. Shows a bad crank position sensor-changed that and jeep starts but runs rough with a miss. Changed the cap,rotor,plugs,wires,still runs rough when cold but does get better once it's warm. Now it throws a code that says the crank and cam aren't in sync'. Once warmed up it throws no code. I'm baffled,please help
firefighter1 is offline
post #2 of 2 Old 04-22-2013, 08:25 PM
yjsapper
my brothers o2 tj does the same thing with the same codes. we have replace the crank sensor, plugs, all the 02 sensors, checked for vacuum leaks, cleaned the throttle body and IAC. Still does it when its a cold start and around 40 degrees ambiet temp. Totaly lost now.
yjsapper is offline
Rough Idle when Cold Titleistprov21 TJ Wrangler Technical Forum 3 11-05-2009 10:54 AM
Rough Idle on Cold Start rugbynut YJ Wrangler Technical Forum 15 03-13-2008 12:37 PM
Rough idle on cold/first startup of the morning. abnormal TJ Wrangler Technical Forum 18 08-15-2007 10:09 AM
Rough cold idle ckcarr TJ Wrangler Technical Forum 1 11-10-2004 03:45 AM
Rough Idle on cold engine fire-up 69440dart TJ Wrangler Technical Forum 6 09-09-2003 05:43 PM
