Rough Idle and surging engine after a battery drain - JeepForum.com
post #1 of 12 Old 07-18-2012, 02:32 PM Thread Starter
eruji
Left my jeep untouched for about 4 days, went to start it and it did the rapid clicking noise. I was able to jump start it drive it 10 miles down the road and at my first stop light the engine idled low and died.
I could start it and was able to gas it at the same time to get it pulled off the road. Then after a few more failed starts the battery was dead again. Towed back to home, replaced the battery and cleaned out the throttle body and the IAC solenoid. As i was cleaning out the IAC i accidentally pulled the plunger out of it, so the threaded part was yanked out and didnt seem to want to screw back on, meaning it was just endlessly spinning. So im assuming that is my problem. Just seems weird to have both the battery and the IAC go out at the same time.
So reassembled the semi broken IAC and clean throttle body and new battery. And now it starts but will either die after i let go of the throttle or it will surge at a very low rpm and sound like its on the verge of dying. Does that sound like an IAC issue?
eruji is offline
post #2 of 12 Old 07-18-2012, 03:30 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Charge your battery overnight. Not an hour, not three hours... either all day or, better, overnight. The engine will either not run or barely run with a dead or weak battery. The type of alternator the TJ uses requires a good solid 12v from the battery before it can produce enough power to run the engine.
Jerry Bransford is offline
post #3 of 12 Old 07-18-2012, 03:39 PM Thread Starter
eruji
Hi Jerry,
Its a brand new battery, that should not be an issue right?
eruji is offline
post #4 of 12 Old 07-18-2012, 03:48 PM
Jerry Bransford
Administrator
Whoops I missed where you said you replaced the battery. The computer gets reset after a new battery is installed so it has to relearn all its parameters. Give it a bit more time to relearn those parameters if the battery is now good.
post #5 of 12 Old 07-18-2012, 03:57 PM Thread Starter
eruji
Yes the battery is now good, no problem starting. When i try to start it, i have to give it some gas to keep it running and then i let off on the accelerator pedal and the RPM's dance somewhere between 0 and the first dot.. seems way too low. it will surge a dozen times or so then die. I have not driven it around yet because im afraid it going to stall in the street.
eruji is offline
post #6 of 12 Old 07-18-2012, 05:46 PM
Tblack
Just drive it bro. Mine did the same thing after my last battery died. The battery was only in for a few months but the battery had previously sat on the shelf for over a year (production date stamped on the side), It was out of water and went haywire. Replaced with a new one and it did this. 10 minute drive and it was running normal.
Safety 3rd!
Tblack is offline
post #7 of 12 Old 07-18-2012, 06:30 PM
TexasTeaJ
TexasTeaJ's Avatar
No check engine light?
"You may all go to hell, and I will go to Texas."
-Davy Crockett
TexasTeaJ is offline
post #8 of 12 Old 07-18-2012, 08:29 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Time to replace that broken IAC.
GOLENJEEPTJ is offline
post #9 of 12 Old 07-19-2012, 02:46 AM Thread Starter
eruji
broken IAC was definitely the issue. Here is a pic of the broken one:
I did take it out for a 10 minute drive just to confirm that the computer needed to be reset and it did still surge on a low idle. Replaced the IAC and all was well again.
Thanks everyone for their input.
eruji is offline
post #10 of 12 Old 07-19-2012, 03:57 AM
redo4x
Had the same problem with mine. The fps sensor would throw a code here and there and give a little trouble. My wife left the lights on at work one day and had rough idle and shutting off all the way home. The fps was throwing multiple codes, reset the computer and it ran fine. I have since then replaced the sensor and it runs great.
33x12.50 Mtz's, Ome lift, 3/4 front spacers, Jks 1.25 bl and mml, Warn 9000, Rockcrawler front and rear bumpers, Warn fog/driving lights, Rubicon flares
redo4x is offline
post #11 of 12 Old 07-19-2012, 09:30 AM Thread Starter
eruji
redo4x, what exactly is the FPS sensor? are we talking about the same IAC?
eruji is offline
post #12 of 12 Old 07-19-2012, 03:59 PM
Jerry Bransford
Administrator
The FPS was a typo, he meant TPS sensor... throttle position sensor.
rough idle, surging, backfiring, then runs fine, distributor? autopc25 TJ Wrangler Technical Forum 4 07-14-2012 10:11 PM
Jeep won't idle after battery drain freeskier93 TJ Wrangler Technical Forum 8 10-17-2009 08:56 AM
Runs rough after battery drain? Deadhorse TJ Wrangler Technical Forum 2 03-16-2009 06:16 AM
95 2.5 Rough Surging Idle Desert Bob YJ Wrangler Technical Forum 22 05-02-2008 12:34 PM
surging idle and surging throttle on warmed freshly turned on engine ChaosMTB TJ Wrangler Technical Forum 2 04-08-2008 08:21 AM
