Rough idle and low RPM in drive...I need help - Page 5 - JeepForum.com
post #61 of 65 Old 11-29-2012, 06:14 PM Thread Starter
Rico25
So the ignition coil was the culprit? Would that cause the plugs to go black? Like as if the were getting a fuel rich mixture? Hopefully this will solve the problem.
Rico25 is offline
post #62 of 65 Old 11-29-2012, 06:49 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Weak spark?...
Knuckelhead is offline
post #63 of 65 Old 11-29-2012, 07:04 PM Thread Starter
Rico25
Second set of plugs since April
Rico25 is offline
post #64 of 65 Old 01-28-2015, 06:40 PM
manderson2228
Sorry to bring up old post, but did you ever solve this? I am having the same problem, and have replaced damn near everything at this point.
manderson2228 is offline
post #65 of 65 Old 08-17-2015, 08:19 AM
jakeohio726
Hi everyone,
I have been experiencing this same issue where my Jeep YJ with Automatic transmission would have a rough idle when driving for a period of time especially in outside temps exceeding 100degrees. Ive noticed this once i put my Jeep in park it would idle smoothly and once i put in drive it would bog down and up and down again like it was about to die. My fix was adding an Aftermarket Transmission cooler to my Jeep. Weird as it seems I had my mechanic check everything from the Cap, Rotor, plugs, vacuum, IAC, computer.....I mean everything until I added the transmission cooler and WALLA.......No more bogging down. My temps do not exceed 200Degrees on my radiator. Jeep runs smoothly at stop signs/lights. So i would recommend adding a transmission cooler if you havent done so. Just my $.02 (Cents) worth.
\m/ Ernest \m/
jakeohio726 is offline
low rpm , please help , rough idle
2004 TJ 4.0 High Idle after Drive, but then normal idle greenjeepsrule TJ Wrangler Technical Forum 6 11-07-2012 11:52 AM
04 lj rough/low idle in drive APEDZ04LJ TJ Wrangler Technical Forum 9 07-24-2012 06:55 PM
rough idle idle issue rescue913 YJ Wrangler Technical Forum 1 10-21-2010 06:57 PM
Rough idle after 1/2 mile drive... NEED HELP!!! poobub TJ Wrangler Technical Forum 8 07-27-2009 04:24 PM
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 06:40 AM
