Rough idle and low RPM in drive...I need help - Page 2 - JeepForum.com
post #16 of 65 Old 06-15-2012, 06:17 PM Thread Starter
Rico25
Update on the idle
I forgot to mention that the idle isn't constant, it comes and goes as it pleases lol. But it is there more often then not but only when in drive and stopped. I am not sure if it is my imagination, but the engine seems to have a bit of hesitation in it.... But I could just be losing my mind lol!
Thnx again for all the tips... Keep em coming
Rico25 is offline
post #17 of 65 Old 06-16-2012, 06:18 AM
BioTex
1979 CJ7
I believe the upstream o2 sensors are the ones to replace.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #18 of 65 Old 06-16-2012, 06:10 PM Thread Starter
Rico25
What is the proper spark plug that I should be using? I need the part #
Rico25 is offline
post #19 of 65 Old 06-16-2012, 06:30 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Champion 7034's work well...
Knuckelhead is offline
post #20 of 65 Old 06-16-2012, 06:48 PM
WindsorRenegade
Are those the truck plugs, Knuckelhead? I can't seem to find them. I just got the normal Champs for these things.
Originally Posted by ruthole View Post
I just bumped it around till it was in the hole and she went right in. But my hands were hard to fit in there.
WindsorRenegade is offline
post #21 of 65 Old 06-16-2012, 07:02 PM
Knuckelhead
AFSOC Retired
Your local automotive parts store should have no problem looking them up?...
post #22 of 65 Old 06-16-2012, 07:20 PM
WindsorRenegade
Yeah, the parts guys 'round here are generally useless. Which is strange, because Windsor and Detroit are naturally, full of gearheads. Normally just some young kid who's really only doing counter duty. I've asked and they say they're discontinued/hard to come by, which I thought was weird.
I'll have to wait till one of the old dudes are at the counter. They've never steered me wrong.
post #23 of 65 Old 06-16-2012, 07:27 PM Thread Starter
Rico25
Ok, so my next move is to get champ spark plug( 7034) and replace them, and double check the ignition coil when doing so to ensure good contact. If the doesn't work then I will take out the upstream o2 sensor. Do I have to do any wire cutting or anything? Or is it just plug and play with 7/8 o2 sensor socket?
Rico25 is offline
post #24 of 65 Old 06-16-2012, 07:34 PM
WindsorRenegade
That's it.
post #25 of 65 Old 06-17-2012, 03:20 AM
mattlock1983
mattlock1983's Avatar
Originally Posted by jeepinhokie
i have a similar problem. 04 TJ with 42RLE. Engine idles around 3-400 RPM when its hot outside. Not terribly rough, but you can tell that its stumbling over itself. put it in neutral and the RPMs climb up at touch and the rough idle goes away.
Ive cleaned my throttle body replaced my TPS. IAC is next on the list to replace.
interested in seeing what becomes of this.
i would suspect that your plugs are not the proper ones; and thinking about it, that might be my problem.
When I had this problem, a computer reset fixed it. After cleaning the iac, etc.. I had to pull the battery cables off for about 15 min, to force the computer to reset and "relearn" the " new" air/fuel curve.
2004 Rubicon Artic Silver, Automatic
~2.5" Lift, LT285 MTR's, Currie HD steering, Currie Anti-Rock, Nth Oil Pan Skid, Kilby Steering Skid, Warn HS9500, Rockcrusher Diff covers, Nth Slider rear DS skid, custom bumpers, PIAA reverse lights, Tuffy Console, Uniden PC78 elite CB, Nth TT (not installed)
mattlock1983 is offline
post #26 of 65 Old 06-18-2012, 05:34 AM
jeepinhokie
Ive reset my computer a few times since the onset of this issue. ill try a new IAC sometime soon and see if that clears it up.
HOKIES UNITED!
jeepinhokie is offline
post #27 of 65 Old 06-24-2012, 06:18 PM Thread Starter
Rico25
Update on rough idle
Hey guys,
So I changed out the o2 sensors ( upstream) and still no luck. Any other suggestions that I can check? I still haven't done the new spark plugs but I checked the connection on the ignition coil and it seems ok. Could it be a fuel delivery problem? I know the fuel filter and pump are in the gas tank but should I check the fuel pressure or something along those lines?
Thanks guys
Rico25 is offline
post #28 of 65 Old 06-24-2012, 10:58 PM
mattlock1983
Hey guys,
Thanks guys
have you checked to see if it is throwing any codes?
as far as fuel delivery problems: i see that you have a 2004, and so i can assume that you have <80,000 miles. if this is the case, i would not immediately consider the fuel filter to be the problem. however, i also see that you are located in Canada, and i am unfamiliar with the fuel requirements in Canada. if you suspect that you have been using "dirty" gas, then it may well be posible that your fuel filter is at fault. however, i feel like if it were in fact a dirty fuel filter at fault, (or any fuel delivery problem) then you would notice it across all rpm bands, esp at WOT, and not just a bit of stumbling at idle. that is my $0.02
post #29 of 65 Old 06-24-2012, 11:12 PM Thread Starter
Rico25
It is not giving any codes and when I was at the jeep dealership ( against my better judgement) the mechanic mentioned that the fuel mixture is on the lean side. Should i try the battery disconnect and the computer "relearn" the specs of the engine?...
Rico25 is offline
post #30 of 65 Old 06-24-2012, 11:20 PM
20024BangerTJ
The same thing happened to me try changing your MAP sensor
20024BangerTJ is offline
low rpm , please help , rough idle
2004 TJ 4.0 High Idle after Drive, but then normal idle greenjeepsrule TJ Wrangler Technical Forum 6 11-07-2012 11:52 AM
04 lj rough/low idle in drive APEDZ04LJ TJ Wrangler Technical Forum 9 07-24-2012 06:55 PM
rough idle idle issue rescue913 YJ Wrangler Technical Forum 1 10-21-2010 06:57 PM
Rough idle after 1/2 mile drive... NEED HELP!!! poobub TJ Wrangler Technical Forum 8 07-27-2009 04:24 PM
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 06:40 AM
