Rough Idle and CEL after tune up - JeepForum.com
post #1 of 3 Old 06-24-2010, 10:42 AM Thread Starter
deacfire
Hey everyone
So last week I decided to do a tune up on my 97 TJ (6 cylinder). Spark Plugs i removed were old but in fairly good shape.
I replaced the air filter, the plugs and wires. Used Champion double platinum plugs and champion wires. Since the tune up the TJ has been idling rough and the CEL has come on. When idling it sounds like it is misfiring and it smells of unburnt gas. Also exhaust from tail pipe, while not smoky, is a little black.
I rechecked all the plugs and wire and the plug has a nice black coating on them (after only 200km or so) and the mileage has noticeably declined.
Any idea what may be the problem? The jeep was fine before i did the tune up so not sure why is is acting up now!
deacfire is offline
post #2 of 3 Old 06-24-2010, 10:49 AM
Imped
Imped's Avatar
Don't use double platinum plugs in the older motors. Switch to the standard plugs and you'll be good to go.
OlllllllO
IndyORV
Imped is offline
post #3 of 3 Old 06-24-2010, 12:49 PM
Unlimitedlou
Change the plugs. Use plain old stock plugs.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
rough idle , cel , check engine light
Engine running really rough even after tune-up...any suggestions? JrTjK YJ Wrangler Technical Forum 3 12-18-2008 08:11 AM
Idle stumble after tune up 69junk YJ Wrangler Technical Forum 3 11-29-2008 01:45 PM
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 06:40 AM
TJ rough idle and tune up suggestions RckRdyXJ TJ Wrangler Technical Forum 3 03-22-2006 03:28 PM
rough idle after tune up? jimmysjeepn YJ Wrangler Technical Forum 4 09-20-2004 07:12 PM
