Rough Idle After 3" TF Lift (with transfer case drop) - JeepForum.com
post #1 of 24 Old 03-08-2012, 09:01 AM Thread Starter
bclark11
Hey Guys,
I need some help. I installed a 3" Teraflex coil spring lift with their adjsutable front trackbar, tansfercase drop, bilstein 5100's, JKS QD's, rear track bar bracket, stock control arms, 15" ravines, stock GY wrangler 30x9.5's. All of this on a 2004 Jeep TJ with D30 upfront and D44 in the rear 3.73 gear ratio. Stock driveshafts and no modifications to the transfercase (other than the drop). No body lift or motor mount lift. No spacers.
Since the install I have started noticing a few issues... the first of which is DW (I am not starting a new DW thread here so please no comments on that..) The other issue (and the purpose of this thread) is that I have noticed that my engine idles differently. It seems like it is running fine (no overheating, no hickuping, etc... but it is vibrating different and you can feel the vibrations in the seat and center console, steering wheel, basically anything attached to the body of the Jeep. I just want to make sure this is not a serious issue.
My first thought is that maybe it's because of the transfer case drop... maybe the engine doesn't like running at a rearward cant??? It also seems like my clutch/transmission is louder at idle... not sure if the two are related...
Anyone have experience with this? I would appreciate your feedback!
Thanks,
-BMC
Who Dat?
bclark11 is offline
post #2 of 24 Old 03-08-2012, 10:00 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Did you align it immediately after the lift install?(DW)The other sounds like driveline vibes from the lift.I'd do a MML.If it's actually a rough idle,maybe you pulled a vacuum line loose slightly.
TheBoogieman is offline
post #3 of 24 Old 03-08-2012, 10:04 AM Thread Starter
bclark11
Yes, alignment was done immediately... the vibration goes away when driving... its only at idle. I do however, have a bit of driveline vibration at take off in 1st but this is a separate issue (i think).
Who Dat?
bclark11 is offline
post #4 of 24 Old 03-08-2012, 10:11 AM Thread Starter
bclark11
let me clarify...
In my opinion, I have 3 separate vibration issues after the lift.
1. rough vibrations at idle
2. very minimal driveline vibes at take off in 1st gear
3. Death Wobble
In this tread I am trying to diagnose the first issue (rough vibes at idle). The driveline vibes are a simple fix, the death wobble is its own issue that I am in the process of resolving.
SO... I guess the essential questions are:
Has anyone else noticed changes to their idle feel after installing a lift and transfercase drop? If so, is it serious? Where you able to diagnose and fix the issue?
Who Dat?
bclark11 is offline
post #5 of 24 Old 03-08-2012, 02:14 PM Thread Starter
bclark11
Bump... Need some help.
Who Dat?
bclark11 is offline
post #6 of 24 Old 03-08-2012, 02:35 PM
4banged
I don't think the rough idle would have anything to do with the new lift unless you bumped something like boogie said. I would do a tune up if you haven't in awhile because it could be something as easy as a plug that just happened to go bad at about the same time as the lift install. My driveline vibes were at around 35mph and I don't think I've read about anyone getting them when they start out in 1st gear but maybe someone else can chime in.
4banged is offline
post #7 of 24 Old 03-08-2012, 02:41 PM
RedStep
Yeah driveline shaking is common with lifts, and I'm almost inclined to say you need an SYE but the tcase drop should have eliminated the need on the smaller lift. Check if you bumped something first but if you turn the truck on and stick your head underneath you might be able to tell what's wrong a little easier
RedStep is offline
post #8 of 24 Old 03-08-2012, 03:17 PM Thread Starter
bclark11
I should do the MML in addition to or in replacement of the transfercase drop?
Where can I look to see if I pulled a vacuum tube?
Thanks for your help,
-BMC
Who Dat?
bclark11 is offline
post #9 of 24 Old 03-08-2012, 03:21 PM Thread Starter
bclark11
Just replaced plugs about 2000K ago... what I am experiencing and calling driveline vibes is a little shimmy I feel on the shifter. It goes away after I hit about 6 MPH (about the time I shift to 2nd).
-BMC
Who Dat?
bclark11 is offline
post #10 of 24 Old 03-08-2012, 03:22 PM Thread Starter
bclark11
What should I be looking for?
Who Dat?
bclark11 is offline
post #11 of 24 Old 03-08-2012, 05:25 PM
RedStep
Look at the angles of the driveline components. You might be able to hear what's making the noise, that's my best guess without actually feeling for myself
RedStep is offline
post #12 of 24 Old 03-08-2012, 05:50 PM
rkymtn05
This might sound like a dumb question and don't take offense to it because I'm just trying to help. Did you loosen the nuts on the transmission mount that attaches to the skid plate when installing the drop brackets and then retighten afterward? Sometimes I find that some of the problems I experience with my jeep are because I overlooked a simple step. So basically your idle isn't rough, you just feel the rpm of the motor transmitted through the body at idle? Did you change motor mounts or transmission mount at the same time to something other than oem? After I installed my UCF lopro mount with the rubber bushing I could feel the motor vibrations more at idle but as soon as the rpm rises even slightly there is no difference than before.
All that is necessary for the triumph of evil is that good men do nothing.
rkymtn05 is offline
post #13 of 24 Old 03-08-2012, 06:06 PM Thread Starter
bclark11
Not a dumb question at all. That's the first thing I thought of too. I did loosen them before dropping the tcase and retightened them afterwards. Didn't change motor mounts or tranny mounts.
Who Dat?
bclark11 is offline
post #14 of 24 Old 03-08-2012, 06:11 PM Thread Starter
bclark11
Okay thanks. I'll crawl under there tomorrow and check it out. Not really hearing a noise though. Just vibes at full stop and idle.
Who Dat?
bclark11 is offline
post #15 of 24 Old 03-08-2012, 06:13 PM Thread Starter
bclark11
Now that I think about it, do you know the torque spec for those transmission mount bolts? I don't remember torquing them... That could be the issue I guess. I did tighten them though.
Who Dat?
bclark11 is offline
Rough Country 2.5" coil lift--Anyone actually use the T-case drop? NextJeep TJ Wrangler Technical Forum 8 05-08-2011 06:11 PM
should i drop the transfer case with a 2.5" lift and 1" boomerang shackles?? eric0024 YJ Wrangler Technical Forum 5 09-28-2008 10:23 AM
Transfer Case Drop Needed with 2" Lift? PSYCH0 TJ Wrangler Technical Forum 10 06-23-2008 06:12 PM
1" transfer case drop + 1" body lift = ?? YJames90 YJ Wrangler Technical Forum 6 11-09-2007 08:40 AM
Transfer case drop needed on an LJ with a 3" lift? snsmith86 TJ Wrangler Technical Forum 11 02-05-2007 10:39 AM
