Rough Idle - JeepForum.com
post #1 of 6 Old 04-01-2008, 11:53 PM Thread Starter
bikerman02
Rough Idle
I have an 06 rubicon unlimited and once in a while it will idle weird. Rpms go up to 1000 and you can feel the engine shake like its about to stall but computer keeping it from doing it. A/C on or off same and it does it at radom times. Usually when stopoed at a red light it will do it. Any Idea or just normal.
bikerman02 is offline
post #2 of 6 Old 04-02-2008, 09:31 PM
rmr76
I had the same issue on mine and it turned out to be the throttle position sensor.
rmr76 is offline
post #3 of 6 Old 04-02-2008, 09:38 PM
redhsv143
redhsv143's Avatar
Is your check engine light coming on at all?
redhsv143 is offline
post #4 of 6 Old 04-02-2008, 10:40 PM
chrisjep97
tune up maybe?
it runs...........well the important thing is it runs
low output 4cyl jeep club member #150
chrisjep97 is offline
post #5 of 6 Old 04-02-2008, 11:15 PM Thread Starter
bikerman02
13000 miles on her and no engine light. Does it at random times but only when stoped at a light or parked. Other than than runs perfect. Its done it since I bought it last christmas. 2nd time this month its done it.
post #6 of 6 Old 04-03-2008, 05:41 AM
hunter44102
A throttle body cleaning might solve the problem. You can do it yourself or pay $60 at a lube place (like Valvoline instant oil change)
hunter44102 is offline
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 07:40 AM
AC on idle rough coastiejohn YJ Wrangler Technical Forum 4 08-19-2007 09:14 PM
Rough Idle themajor YJ Wrangler Technical Forum 3 08-26-2004 09:48 PM
Carter BBD fix for No Idle or Rough Idle ScotZ YJ Wrangler Technical Forum 0 03-26-2003 10:26 PM
rough idle jaykump TJ Wrangler Technical Forum 5 11-19-2002 08:21 AM
