Rough Idle - JeepForum.com
post #1 of 3 Old 11-01-2013, 10:32 AM Thread Starter
gordopizza
Rough Idle
So Ive been trying to rule this problem out for two days now. First it wouldn't start. I turned the key with a clicking noise. So I did some research and replaced the starter relay and the TPS. Still no cigar. Then I saw my battery leads were a little corroded so I cleaned them up a bit. Now I have a start but their is a rough idle, sometimes it even stalls. The first time it started it also took a while to idle and it smelled a little bit like gas. So now i'm stuck. Any help would be appreciated.
BTW
01 Jeep TJ 104,000 miles
gordopizza is offline
post #2 of 3 Old 11-01-2013, 11:03 AM
Cuder
Did you clean the throttle body and IAC port when you put the TPS on?
My Build Thread:
Cuder is offline
post #3 of 3 Old 11-01-2013, 11:08 AM Thread Starter
gordopizza
No I didn't. Would that just happen out of the blue though? It started fine the other day.
clicking noise , rough idle , smell gas
