Rough idle. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rough idle.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 08-11-2010, 11:58 AM   #1
2006_Sport
Rough idle.
I searched and couldn't find anyone with my symptoms really. I went wheeling this past saturday and it drove great on the way to the outer banks the monday after. I went drove it on the beach a few times and noticed that at a stand still the Jeep has developed a rough idle, i can feel it in the *** of my seat. The engine seems like it may be sputtering a bit?, idles at the normal level...it's just more vibey than normal. It only does it at a stand still after driving for a few minutes. Oil pressure is fine, engine temp is okay too. I cleaned the underside as best I could to remove all the mud but theres still a good amount on the top side of my t case skid plate...could that be the cause of it?
What could be the culprit? TPS? Throttle body? Spark plugs?
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| IPF|Alpine|JKS|PoisonSpyder|Truck-lite|Aussie Locker|Novak|Trail Gear|Firestik
Originally Posted by Hudson View Post
There are no women on the internet either. Learn that. It's a fact.
-Zach
2006_Sport is offline   Reply With Quote
Unread 08-11-2010, 12:07 PM   #2
jeepin97tj
is your check engin light on it could be the o2
jeepin97tj is offline   Reply With Quote
Unread 08-11-2010, 12:10 PM   #3
2006_Sport
I did get a CEL for one of my 02 sensors giving a slow response before I left for vacation, this code to be exact P0133. I reset the codes and it never came back. Could be that? I have no idea which 02 sensor it would be though
SUPPORT THE TROOPS
-Zach
Unread 08-11-2010, 12:10 PM   #4
Redryan98
Mine has done this since I bought it (TJ 6Cyl). Just a bit of a rough idle (feels like misfire). I did get a code for misfire cylinder 1. Swapped plugs on cyl 1 and 2 to trouble shoot. CEL has not come back but rough idle remains. I'm thinking about checking timing next.
Good luck with yours. Keep us posted if you find resolution
Redryan98 is offline   Reply With Quote
Unread 08-11-2010, 12:23 PM   #5
2006_Sport
Well I just looked at the 02 sensor on the exhaust behind the front diff....its covered in mud. Maybe that caused it to go bad. I'll pull it when I get home to MD in a week and look at it.
SUPPORT THE TROOPS
-Zach
Unread 08-11-2010, 12:48 PM   #6
vindicated
Survivor
vindicated's Avatar
Mine idles rough as all hell but not a single code is thrown. It's wierd, I have new plugs, cleaned the TB and components, various other things. I can't figure it out...
www.paracordforum.com
Originally Posted by bradthebard
Vin's so hard core, he drinks the whole jug of STFU and then has a three hour conversation about it.
vindicated is offline   Reply With Quote
Unread 08-11-2010, 12:49 PM   #7
Sundowner
Part-Time Swami
Sundowner's Avatar
For your rough idle issue, I'm going to suggest cleaning the throttle body and the idle air controller before you do anything else. Mud on the O2 sensor shouldn't have anything to do with it, although a slow response code could come from frayed/cracked wiring, a sensor that's slowly dying, or even from an exhaust leak. Check the connections to the sensors and the harness wiring before you rip one out and replace it.
The build, the gear, and the mileage: The Wasteland Survival Guide
Sundowner is offline   Reply With Quote
Unread 08-11-2010, 01:01 PM   #8
2006_Sport
Sounds good sundowner. I'll clean it n stuff when I get home along with the IAC as well. It's just weird, the rpms go nowhere but you can feel it idle a lil rougher.
SUPPORT THE TROOPS
-Zach
Unread 08-11-2010, 01:25 PM   #9
wrangler0289
yuhhhh. reall talk East Coast. READ MY SIG
"Remember getting your shell cracked is only a phone call away"
wrangler0289 is offline   Reply With Quote
Unread 08-11-2010, 01:27 PM   #10
2006_Sport
, AJ you're an idiot. We'll mess with the sparks and TB when I get home.
SUPPORT THE TROOPS
-Zach
Unread 08-11-2010, 03:36 PM   #11
2006_Sport
Anymore thoughts? It's aggravating how this issue comes up now but drives great 2 days after I'm done wheeling. Its almost like a vibe now, i feel it in my seat and I can hear it vibrating some plastic parts in the jeep.
SUPPORT THE TROOPS
-Zach
Unread 08-11-2010, 03:41 PM   #12
vindicated
Survivor
vindicated's Avatar
Exactly the same here Zach. RPM's don't change, idles like ****, and I cleaned the TB and IAC, checked all the wires. It's a ****ing mystery!
Unread 08-11-2010, 03:48 PM   #13
2006_Sport
Yeah I don't get it. I guess when I get home I'm gonna go rambo on the underside of my jeep with a hose and get all of that mud out. Then go through what was said here.
SUPPORT THE TROOPS
-Zach
Unread 08-11-2010, 03:50 PM   #14
vindicated
Survivor
vindicated's Avatar
Yeah, I even seafoamed which didn't do ****. I should have just used water. That being said, thanks for this thread because now I am depressed again about how ****ty it runs and I realize I will never be able to find it.
Unread 08-11-2010, 09:26 PM   #15
MisterO
ill jump on the bandwagon... same s*** with mine since i got it.. oh well
let me know when you guys figure it out.
MisterO is offline   Reply With Quote
rough , idle
