Rough Country4"x install, unlevel rear - JeepForum.com
post #1 of 4 Old 04-27-2007, 08:46 AM Thread Starter
chutta
I just put in rear shocks, sway links and torqued frame u/l arm bolts per spec, suspended one side at a time, weight off suspension and rear end sits high about an inch on drivers side. I verified proper coil placement by micing the coil diameter. will it settle out?
chutta is offline
post #2 of 4 Old 04-27-2007, 09:34 AM
beryl
i think the rough country x series has a taller spring for the passenger side because the jeep transfers torque to the passenger side so the longer spring compensates for it...did you put the longer spring on the passenger side?
beryl is offline
post #3 of 4 Old 04-27-2007, 01:31 PM Thread Starter
chutta
I don't have the directions here at work, but I think it described it as being thicker and put them in as labeled(driver one tagged). A quick mic check last night revealed roughly a .68 driver side, .73 pass.
chutta is offline
post #4 of 4 Old 04-27-2007, 08:16 PM Thread Starter
chutta
I had the springs out, measuring height, put back same. I must have an arm binding?
chutta is offline
Rough Country 1.25" BL install ? DanZ51 TJ Wrangler Technical Forum 17 12-12-2009 06:27 PM
need help with 2.5" Rough Country lift install nycrd JK Wrangler Technical Forum 1 02-19-2009 09:37 AM
looking for install of 4" rough country thread Brown6041 YJ Wrangler Technical Forum 1 12-01-2008 12:16 PM
Jeep rear sits unlevel aklsufan TJ Wrangler Technical Forum 6 06-25-2007 03:26 PM
4" rough country lift install jeepin man99 YJ Wrangler Technical Forum 15 12-19-2006 11:38 AM
