Rough Country wheel spacers - JeepForum.com
post #1 of 14 Old 02-16-2009, 09:08 PM Thread Starter
JP4LIFE
What do you folks think about them? Almost half the price of Spidertrax. How much different can a piece of aluminium be I wonder?
JP4LIFE is offline
post #2 of 14 Old 02-16-2009, 09:35 PM
elkfan2
elkfan2's Avatar
I dont know if I would want to take a chance on wheel spacers.
elkfan2 is offline
post #3 of 14 Old 02-16-2009, 09:37 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
a lot actually.
Read here: http://www.jeepforum.com/forum/f19/wheel-spacers-bad-idea-685684/
Rough Country doesn't list their material and it doesn't look like they're hub centric. Doesn't look like they anodized either. You get what you pay for...stick with Spidertrax.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 14 Old 02-27-2009, 04:37 AM
vfrpilot
a lot actually.
Read here: http://www.jeepforum.com/forum/showthread.php?t=685684
Thanks for the read 04
08 SAHARA 3.8 Lifted
AEV, EMU, 33" NITTO GRAPPLERS
vfrpilot is offline
post #5 of 14 Old 02-27-2009, 06:01 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
My friend has been using the RC ones for awhile with hard wheeling with no problems.People read stuff and freak out over things.Paying more doesn't mean they will work any better.LOTS of people buy the cheapo ebay spacers with no problems.Just make sure to use Loctite on the threads.
TheBoogieman is offline
post #6 of 14 Old 02-27-2009, 06:14 AM
vfrpilot
What up boogie -
Thanks for the input bro.
Yea - although "you get what u pay for" is often true I do know that sometimes you simply overpay...
I'm kickin it around
vfrpilot is offline
post #7 of 14 Old 02-27-2009, 06:19 AM
SeanCucf
I've got the cheapo's on my DD and they work fine. I see no benefit in hub centric, since they center with the lugs like every other wheel on the road and off. As a matter of fact my wheels don't even touch the "hub centric" part anyhow so what good is it? And anodizing isn't all that special either IMO.
SeanCucf is offline
post #8 of 14 Old 02-27-2009, 06:27 AM
vfrpilot
There ya go bud.... thx!!
What size you have.. and do ya have any pics
vfrpilot is offline
post #9 of 14 Old 02-27-2009, 07:28 AM
RCJEEP
Don't be worried about failure, they are solid aluminum and built to last. We have not had any failures and would not put something on the road that we did not 100% trust. Just make sure to check your lugs periodically.
We Stand Behind Our Products!
Satisfaction Guarantee, Lifetime Warranty, 90 Day Full Refund.
RCJEEP is offline
post #10 of 14 Old 02-27-2009, 07:49 AM
Unlimited04
what specific grade of aluminum are you using? 6061-0, 6061-T3, 6061-T4, 6061-T6 or something else?
Useful Write-Ups:
Funny:
post #11 of 14 Old 02-27-2009, 07:54 AM
TheBoogieman
Deeply Disturbed
I think you are the only one who really cares and is worried.I trust RC.
post #12 of 14 Old 02-27-2009, 08:09 AM
Unlimited04
probably true. But if they're using 6061-0 & paint, and no hub centric details, then theres the price difference.
Unlike most people...I'm actually concerned with quality, durability and especially safety for this type of application.
Useful Write-Ups:
Funny:
post #13 of 14 Old 02-27-2009, 08:30 AM
bairy
Unlimited: I do understand all you are explaining and I am sure it is very helpful to many who do not know better. I agree with you on may levels but..
Playing devils advocate:
But are you also to argue is spidertrax made titanium wheel spacers that they would be "better"?
When mounting wheels are torquing the lugnuts properly, does the hub centric bump in the middle provide and real benefit?
Are the aftermarket wheels that are to be mounted going to be hubcentric?
People like using grade 8 bolts for everything because it is stronger, Most times grade 5 is plenty strong enough though. Please back up your decision of needing a higher grade of Aluminum by showing failures of lesser grade in this application.
My M/T aluminum wheels are not clear coated or anodized. I would not have any problem with a non-painted, non-clear coated or non-anodized wheel spacer. Do I live with an inferior finish? sure. Am I looking at my wheel spacers? No
Ultimately, if you have the extra money and you will sleep better at night, get the more expensive ones. If you are on a budget and need to fill an application, the RC spacers are going to work just fine.
In general, everybody wants the best of the best. We have 10 page threads over bolt strength, which suspension is best, which shocks are better, which SYE is better , which axle to use etc.. You are to agree some of the points are trivial at best for the application of most users.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #14 of 14 Old 02-27-2009, 09:30 AM
Unlimited04
bairy, read here on hub centric: http://www.jeepforum.com/forum/showthread.php?t=685684
I wouldn't want titanium spacers - the cost would be rediculous
an inferior finish comes more into place when you try to take them off. if they're corroded onto the hub, due to galvanic reactions, oxide layers or mag-chloride use or salted winter, then thats just one more thing you've got to heat up and bang with a BFH, possibly trashing a stud in the process. For example, here in CO, mag-chloride turns aluminum funny colors, in ohio where you're at, the salt destroys aluminum's oxide layer finish and makes it pit.
As for strength of material - if you want to trust your life to a weaker material, go for it.
6061-O - tensile strength: 18,000 psi, yield strength: 8,000 psi
6061-T6 - tensile strength: 42,000 psi, yield strength: 35,000 psi
Thats why I asked what alloy of aluminum they're using - if they're smart, obviously they'll use T6. When I was shopping for wheel spacers, I found most cheapo ebay spacers were plain 6061.
This is the same principle as Schedule 40 vs DOM. You decide what you want to buy for your application.
btw, I've seen pictures of Spidertrax (6061-T6) spacers cracked in half - possibly due to over-torquing lug nuts.
Useful Write-Ups:
Funny:
Rough Country 2.5" spring & 3/4" spacers extended sway bar links? drewtj05 TJ Wrangler Technical Forum 24 11-04-2009 12:18 PM
to rough country or not to rough country thats the question dw9301998 YJ Wrangler Technical Forum 22 10-07-2009 05:46 PM
rough country wheel spacers anyone? rballman JK Wrangler Technical Forum 4 03-17-2009 07:11 AM
Rough Country or Tuff Country 2.5" Lift? bballard1227 YJ Wrangler Technical Forum 7 09-23-2008 06:55 PM
4" rough country w/ 2" spacers????? tjwhlr00 TJ Wrangler Technical Forum 17 11-07-2006 10:58 PM
