Rough Country SYE & CV Shaft - JeepForum.com
post #1 of 11 Old 07-23-2010, 08:34 AM Thread Starter
bowserw
I was looking around for a SYE & CV Shaft combo that I could get while trying to save some money and I saw that Rough Country has a SYE & CV Shaft for TJs. I was wondering if anyone has used either one and what they thought of it. I can get them for about $425 total, so if its a good setup I'll probably end up getting them for when I do my lift right away instead of putting it off and seeing if I have vibrations.
bowserw is offline
post #2 of 11 Old 07-23-2010, 08:41 AM
RCXTREME
The sye is a Rugged Ridge and the shaft is a Tom Woods.
800-222-7023
www.roughcountry.com
RCXTREME is offline
post #3 of 11 Old 07-23-2010, 08:45 AM Thread Starter
bowserw
Well that makes things easier to research, thanks!
bowserw is offline
post #4 of 11 Old 07-23-2010, 08:57 AM
TJ_ITmgr
That is a great deal. I payed $237 for my Rugged Ridge Mega Short SYE and $200 to have an older waggy front shaft shortened and rebuilt.
1997 TJ, 4.0, 5 Spd, Low miles, Rough Country 2.5" Suspension Lift, 3in body lift, Mega Short SYE and custom shaft, 33x12.50 Maxxis Bighorns, 15x8 Soft 8's, 8.8 Rear w/LS, HP D30 w/LockRight and 3.73's
TJ_ITmgr is offline
post #5 of 11 Old 07-23-2010, 09:12 AM
RCXTREME
That is super cheap. Is that buying if from us?
800-222-7023
RCXTREME is offline
post #6 of 11 Old 07-23-2010, 09:14 AM
Daniel20
Have this kit with a little over 1k on it and no problems.
Daniel20 is offline
post #7 of 11 Old 07-23-2010, 09:44 AM
Jeepzcb09
if i order that kit can i use with a 8.8 axle,cause im getting one very soon
1998 TJ Sport : Rough Country, MetalCloak,KC, Goodyear, Crager, Alpine, AtoZ, Currie, Aussie
Believe.
Jeepzcb09 is offline
post #8 of 11 Old 07-23-2010, 10:46 AM Thread Starter
bowserw
I work for a company that is a dealer for Motor State Distributing, so I would be getting it through work at wholesale cost. Thats actually how I found out about Rough Country, by looking through what companies I can get a discount on. Then I found the RC 3.25 TJ lift which is a setup exactly what I was looking for. Also the RC website is set up great and helped me decide what other options I want to get with the 3.25 lift.
bowserw is offline
post #9 of 11 Old 07-23-2010, 10:58 AM
Jeepzcb09
i get stuff thru motor state to ^^^
Believe.
post #10 of 11 Old 07-23-2010, 11:16 AM
rideraa
FYI I purchased above said parts from RC .. all worked fine ...
For your ref. I have a 4" lift with adjustable long arms, drive shaft length worked fine.
"CHEAP HEAP" TJ, 4.0, 32rh, 231, built D44's, 37s etc.
"George 4man" CJ7, 304, 727, D300, C/O rear w/ stretch, built D44's (4 now) on pane :).
rideraa is offline
post #11 of 11 Old 07-23-2010, 01:01 PM Thread Starter
bowserw
Thanks for all the input, I'll go with this setup!
bowserw is offline
rough country , sye , tj
Rough Country 4" lift series II SYE and Drive shaft colder152000 TJ Wrangler Technical Forum 19 01-20-2010 09:56 PM
Rough Country cv drive shaft richryan07 TJ Wrangler Technical Forum 0 10-17-2009 02:53 PM
to rough country or not to rough country thats the question dw9301998 YJ Wrangler Technical Forum 22 10-07-2009 05:46 PM
rough country bar pin eliminator rough ride after? emahan01 TJ Wrangler Technical Forum 3 02-21-2009 09:05 PM
Rough Country or Tuff Country 2.5" Lift? bballard1227 YJ Wrangler Technical Forum 7 09-23-2008 06:55 PM
