Rough Country Budget Boost no front shock extension ??Why?? - JeepForum.com
post #1 of 10 Old 12-06-2009, 05:22 PM Thread Starter
Mike_Motorbike
The Rough Country 2" leveling Budget Boost only comes with rear shock extensions.
Why wouldn't they give you a front extension if they give you one for the rear??
Especially since the rear only goes up 1" and the front 2"s
Mike_Motorbike is offline
post #2 of 10 Old 12-06-2009, 06:48 PM
brucem
The directions are not real clear. If I remember right you are probably talking about the bump stops.
In the rear put the black hockey pucks between the frame and the bump stop cup and use the new longer bolt in the kit. Put back in the stock bump stop.
On the front put the new longer extended bump stops.
I hope this helps.
brucem is offline
post #3 of 10 Old 12-06-2009, 06:55 PM
Patton
Mike_Motorbike, you are correct in that they only provide the relocation bracket for the rear. I don't know why that was but I don't think it even does anything to lengthen the shock but takes it out away from the spring perch where many lifts over 3" can bang the shock body into the spring perch.
Where I'm getting at is you probably need longer shocks if you are planning to offroad the lest little bit.
94 YJ 4.0/3spd dana 60/44 w/35's 9" of suspension lift
Sold-06 TJ X 4spd auto 3.73
Patton is offline
post #4 of 10 Old 12-06-2009, 06:59 PM
brucem
hummm my RC BB didn't come with any shock relocation brackets, guess that is why I thought he was talking about the Bump Stops.
brucem is offline
post #5 of 10 Old 12-06-2009, 07:03 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you get what you pay for
buy new shocks to accomodate the added lift or make your own shock relocators.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 10 Old 12-06-2009, 07:11 PM
Patton
I believe he has the newer style. Maybe you had the older style.
new style
Patton is offline
post #7 of 10 Old 12-06-2009, 07:39 PM
brucem
Yep I must have had an older one.
brucem is offline
post #8 of 10 Old 12-06-2009, 08:20 PM
jondotcom
When I did my 2" bb I only needed longer rear shocks. The rear shocks were about 1/3" from maxed at ride height but my fronts have several inches of down still.
jondotcom is offline
post #9 of 10 Old 12-09-2009, 01:41 PM Thread Starter
Mike_Motorbike
I called RC and they said they supply a spacer for the front shock..
And a bracket for the rear.
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
post #10 of 10 Old 12-09-2009, 01:56 PM Thread Starter
Mike_Motorbike
On live chat they said you can't use spacers...................
Rough Country JK Budget Boost RockinJK JK Wrangler Technical Forum 33 03-04-2014 01:12 AM
Stock shock life expectancy with a budget boost? IBreakStuff TJ Wrangler Technical Forum 1 01-31-2010 08:56 PM
my budget boost doesn't set level in the front.. Nute4Christ TJ Wrangler Technical Forum 15 01-29-2010 10:24 AM
RE Budget boost shock bushings jmasin3 TJ Wrangler Technical Forum 2 08-02-2009 06:12 PM
Rough Country 2.0 Shock 00jeepsahara TJ Wrangler Technical Forum 7 11-07-2008 01:12 PM
